bzijlstra
Posted: Sat Dec 22, 2012 9:10 am Post subject: WizFi210 - Serial to WiFi |
A blog with some information about the Wiznet WizFi210 module on an Arduino Mega.
Here a picture of the hardware, a WizFi210 on an Arduino Mega shield. You will have to build your own, but all info here.
Ben Zijlstra
Theo Kleijn
Xmas project 2012 - to be continued |
bzijlstra
Posted: Sat Dec 22, 2012 9:31 am Post subject: WizFi210 - Serial to WiFi - hardware |
The hardware design:
WizFi210 with hardware-trigger switch S4, for updating the firmware of the WizFi210, and two buttons and three LED's.
The power part of the board. With a LT1528 power-regulator, with a power-off mode triggered by PWR-OFF
Four level converters for TXD, RXD, RTS and CTS.
Ben Zijlstra
Theo Kleijn
bzijlstra
Posted: Sat Dec 22, 2012 9:41 am Post subject: WizFi210 - Serial to WiFi - additional hardware |
Additional hardware:
To update the firmware to the latest version and to make an initial profile to connect to an WiFi access point, you need a temporarely RS232 level converter.
Temporarely bending two pins on the Arduino Mega shield.
Ben Zijlstra
Theo Kleijn
bzijlstra
Posted: Sat Dec 22, 2012 9:51 am Post subject: WizFi210 - Serial to WiFi - hardware during test phase |
Some pictures of the Arduino Mega shield during a test phase:
The shield without the WizFi210 module
The board with the WizFi210 temporarely connected, just to test
Test phase. In front the WizFi210-evaluation board from Wiznet.
Ben Zijlstra
Theo Kleijn
bzijlstra
Posted: Sat Dec 22, 2012 10:11 am Post subject: Serial to WiFi - WIZSmartScript |
To put the latest firmware in the WizFi210 module and create a profile to connect to an WiFi Access point you have to download the WIZSmartScript from the Wiznet site
The ZIP-file extracted
Start the WIZSmartScript program, baudrate 115200
Find WizFI and Set Command Mode
Do an Access Point scan and select the Access Point to associate with
Select the WiFi security. In this case WPA with the Passphrase 'wisclub1'
Give the module a static IP address (or if you want, give it a DHCP IP address)
Here you can change the Serial port options
For this example we will be using UDP traffic to a PC in our network that has the IP address 192.168.0.237 listening to port 5000
Select an save option. Here you create an startup profile for the WizFi210 module.
You enable auto connect on the next reboot and enable UART messages.
Save the script for later use.
We saved it with the name benshobbycorner and here an example of a script.
Ben Zijlstra
Theo Kleijn
bzijlstra
Posted: Sat Dec 22, 2012 10:29 am Post subject: Serial to WiFi - Bascom-AVR code and output |
Remove the temporarely RS232 level converter and bend the two pins of the Arduino Mega shield back.
The two pins are connected to INT0 / INT1 of the Atmega1280 and thanks to SIX1, we got a program from a earlier project with the WIZ610wi wireless module with some nice serial routines.
Code: | 'Arduino Mega 1280 - WIZFI210
$regfile = "m1280def.dat"
$crystal = 16000000
$baud = 115200
$hwstack = 80
$swstack = 80
$framesize = 90
Poweroff Alias Portj.1
Config Poweroff = Output
Dim Connect As Byte
'put power on the shield
Set Poweroff
Wait 5
Reset Poweroff
'PD.0 = TX
Open "comd.0:115200,8,n,1" For Output As #10
'PD.1 = RX
Open "comd.1:115200,8,n,1" For Input As #11
' ARDUINO HARDWARE SERIAL
Config Serialin = Buffered , Size = 60 , Bytematch = 13
Open "com1:" For Binary As #1
Dim Incoming_data As String * 60
Print #1 , "Start programma"
' INT0 RX INTERRUPT
Dim Timeout_rx As Word
Dim Rx_ok As Byte
On Int1 Isr_rx Nosave
Config Int1 = Change
Enable Int1
' VARIABLES
Dim B As Byte
Dim Pos As Byte
Const Max_rx = 100
Dim Incoming_str As String * 150
Dim Incoming(max_rx) As Byte At Incoming_str Overlay
' START PROGRAM
Print #1 , "Arduino WIZFI210"
Connect = Instr(incoming_str , "[CONNECT 0]")
If Connect = 3 Then
Print #1 , "Connected"
Exit Do
Waitms 10
Wait 1
Print #10 , "abcdefg"
' send USB RX to WIZ
Serial0charmatch:
' send command from USB to WIZ610
Input Incoming_data Noecho
'Print #10 , Incoming_data
' RX from WIZ on SoftSer
Isr_rx:
Disable Int1
Timeout_rx = 0
Incoming_str = ""
Pos = 1
B = Inkey(#11)
If B > 0 Then
If Pos < 120 Then
Incoming(pos) = B
Incr Pos
Timeout_rx = 0
Else
Incr Timeout_rx
Loop Until Timeout_rx = &H1FFF
'set string end position!
Incoming(pos) = 0
Print #1 , Incoming_str
Print #1 , "-"
Rx_ok = 1
'clear INT0 Int Flag, because int can be flaged in meantime!
Eifr.intf1 = 1
Enable Int1
Start Bascom-AVR terminal on 115200 baud and you should get this:
If everything is correct, you will see something on the terminal screen, and when there is an associate with an Access Point two LEDs are on on the WiFi210 Arduino Mega shield.
From the www.hw-group.com download their amazing Hercules program and configure it to use UDP on 192.168.0.80 port 5000 (in the picture we have used port 8888), and if everything is working you should get the abcdefg from your Arduino Mega WizFI210 shield.
Wireless UDP connection working. The third LED on the Arduino Mega WizFi210 shield will blink everytime an abcdefg is send over the network.
Ben Zijlstra
Theo Kleijn
MAK3
Posted: Sun Dec 23, 2012 10:29 am Post subject: |
Hi Ben,
as always, it is a pleasure to follow and read your projects.
MAK3 |
six1
Posted: Sun Dec 23, 2012 3:16 pm Post subject: |
Thanks Ben, for all your work, creativity and bringing up new Chips and solutions! _________________ For technical reasons, the signature is on the back of this message. |
Posted: Mon Dec 24, 2012 12:09 pm Post subject: |
hi Ben & Theo
I see you teamed up again for another great project
This is good reading. Thanks for the pics. It is very clear.
Few questions.
- Can you post a link to the pdf of the used module
- where can we buy this nice arduino board?
- is this wiznets own chip/module? their previous wifi modules only had their name if i remember correctly.
you guys rock, thank you for sharing. looking forward to the other posts _________________ Mark |
bzijlstra
Posted: Sat Dec 29, 2012 8:52 pm Post subject: Serial to WiFi - WIZSmartScript |
WizSmartScript seems to be a shell around the gs_flashprogram.exe
