Posted: Wed Oct 17, 2012 7:56 am Post subject: BGF graphic converter problem
Dears,
I encountered a problem to convert .BMP file to .BGF with the graphic converter tool.
I use an ea dogm128 graphic display connected on the D port of an xmega128A1.
The code is the MAK3 one published in the AN#192. Bascom version is 2.0.7.5.
Existing bgf works OK but not the one's done with the graphic converter
I set two bgf's side by side to illustrate the problem (file enclosed)
The left one is a bgf directly issued from the AN#148.
The right one is the result I get from the left image .BMP source file conversion.
Same source different result so.
Thanks in advance for any suggestion!
