s = hex(const)
uga237
PostPosted: Tue May 29, 2012 7:46 am    Post subject: s = hex(const) Reply with quote
$regfile = "xm256A3def.dat"
$crystal = 32000000
$hwstack = 1024
$swstack = 1024
$framesize = 1024
Const Value = &HAA
Dim Str_a As String * 30
Str_a = Hex(value)
Error : 42 Line : 10 Numeric parameter expected [170] , in File : C:\Atmel\PDA\BASCOM\PDA\noname3.bas
want to work it )
uga237
PostPosted: Tue May 29, 2012 7:48 am    Post subject: Re: s = hex(const) Reply with quote
not to offer a:
$crystal = 32000000
$hwstack = 1024
$swstack = 1024
$framesize = 1024
Const Value = &HAA
Dim B As Byte
B = Value
Str_a = Hex(b)
Luciano
PostPosted: Tue May 29, 2012 1:35 pm    Post subject: Reply with quote
Try that:
Const MyStringHexValue = "AA"
Str_a = MyStringHexValue
The HEX() function expects a variable and will use code space and resources at run-time.
Best regards,
Luciano
uga237
PostPosted: Tue May 29, 2012 1:58 pm    Post subject: Reply with quote
uncomfortable, and the use of constants in this form is convenient
uga237
PostPosted: Tue May 29, 2012 2:00 pm    Post subject: Reply with quote
and logical
PostPosted: Tue May 29, 2012 3:29 pm    Post subject: Reply with quote
str() behaves the same. it expects a variable since a constant has a value already known, and when i added the hex/str functions i could not see benefit from converting already known values:
const x=170
s = str(x) , which would be "170". For the hex, yes, that is not so obvious. i will add it to the next release. the compiler will replace the constant and assigns a string constant : s = "AA".
