Problem with RS-232 interfacing
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
dhruvil_90
PostPosted: Mon Apr 09, 2012 1:02 pm    Post subject: Problem with RS-232 interfacing Reply with quote
Hey guys. I have a problem with interfacing my bluetooth module (aubtm-20) with Atmega 640. The BT module works perfectly and responds to the commands sent when connected directly to a PC. I have also debugged the code and it works perfectly. But when I connect the BT module (Rx and Tx pins are connected to MAX232 and then to DB9 connector) to the microcontroller using DB9 connector + MAX232, I get incomplete response.
For example, instead of getting getting the response as "<CR><LF>OK<CR><LF>", I get a response like "<CR><LF>O<LF><CR><LF>". The response I get seems to be a part of the actual response but I get a different response everytime.
Rx of BT module is connected to Tx of microcontroller and Tx of BT module is connected to Rx of microcontroller.
I also have shorted grounds of both the boards and have ensured that the baud rates are proper.
Please let me know what the problem could be.
hgrueneis
PostPosted: Mon Apr 09, 2012 4:33 pm    Post subject: Reply with quote
Hard to tell without the code and any other info.
Did you check the status report to see the %-deviation of the com?
Sometimes setting the internal pull-up on RX helps.
Hubert
edit: What you post looks like a character overrun.
Mostly happens if you spend too much time in an ISR.
Do you use serial buffer or polling...bytematch....???
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
