Problem with I2C (hangs with I2cwbyte)
HolgerBri
PostPosted: Sun Mar 18, 2012 9:36 pm    Post subject: Problem with I2C (hangs with I2cwbyte) Reply with quote
my program hangs up when trying to send data via I2C to HMC5843 Magnetometer. (whole code is attached)
' Konstanten für die Ansteuerung von HMC5843
Const Hmc_write = &H3C
Const Hmc_read = &H3D
' Variablen
Dim Grad As Integer
Dim Bgrad As Byte
' Hauptprogramm
Led = 1
Zeige7seg 10
I2cinit
Zeige7seg 20
' Setze IC in Continous Modus
I2cstart
Zeige7seg 30
I2cwbyte Hmc_write
Zeige7seg 40
The line Zeige7seg 30 is executed but not the line Zeige7seg 40 . After executing I2start Err is 0. I wonder what leads to this hang up without any error code. Do you have an idea? Btw: I also tried without I2cdelay
Best Regards
Holger
PostPosted: Mon Mar 19, 2012 12:20 am    Post subject: Reply with quote
I do not see anywhere in the code the required startup delay, as given by the data sheet:
To change the measurement mode to continuous measurement mode, after the 8.3 milli-second power-up time send the three bytes
Also stack and frame settings are missing, then the setting from the IDE are used, which will not necessarily be sufficient.
Also be aware that soft-I2C needs external pullups, while hard-I2C may work with the µC's internal ones.
HolgerBri
PostPosted: Mon Mar 19, 2012 6:51 pm    Post subject: Reply with quote
Thanks! the pullups were the solution. In the datasheet they mentioned that the pullups are integrated - but this seems not to be enough!
Best Regards
Holger
PostPosted: Mon Mar 19, 2012 8:06 pm    Post subject: Reply with quote
Fine Very Happy
Well it reads differently.
Depending on the application, the internal pull-ups may be used to support slower data speeds than specified by I2C standards.
And:
This device shall support standard and fast modes, 100kHz and 400kHz respectively, ... External pull-up resistors are required to support these standard and fast speed modes.
