problem with i2c libary
boeseturbo
PostPosted: Tue Feb 28, 2012 8:37 pm    Post subject: problem with i2c libary Reply with quote
Hi friends,
now I was sitting half day to get i2c slave libary to run Sad((( I use 1281 as master (tried software i2c and hardware i2c) and attiny13 as slave device. Hardware is connected correct. 1281 can also read LM75 without any problems....
Here is my code for attiny13:
$regfile = "attiny13.dat"
$crystal = 9600000
'$baud = 57600
Config I2cslave = &H30
Config Adc = Single , Prescaler = Auto , Reference = Internal
Start Adc
Dim Choicer As Byte
Dim Wert_adc As Word
Dim Wert_byte As Word
Dim Wert_send As Byte
If Choicer = 1 Then Wert_adc = Getadc(2)
If Choicer = 2 Then Wert_adc = Getadc(3)
I2c_master_needs_data:
_a1 = 100
I2c_master_has_data:
Choicer = _a1
master is:
$crystal = 16000000
$regfile = "M1281def.dat"
$baud = 4800
$hwstack = 600
$swstack = 600
$framesize = 600
$lib "i2c_twi.lbx"
Config Scl = Portd.0 ' we need to provide the SCL pin name
Config Sda = Portd.1 ' we need to provide the SDA pin name
Config Twi = 100000
I2cinit
do
I2cstart
I2cwbyte &H31
I2crbyte Test1 , Ack
I2cstop
waitms 20
loop
only "255" come back... so might be an error.... Have anybody an idea? I also tried software i2c on atmega1281... no luck Sad
Cheers
boeseturbo
PostPosted: Tue Feb 28, 2012 9:06 pm    Post subject: Reply with quote
shit, bought wrong slave-cpu... should be tiny12 Sad
MAK3
PostPosted: Tue Feb 28, 2012 9:26 pm    Post subject: Reply with quote
should be tiny12
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&p=22764#22764
MAK3
PostPosted: Wed Feb 29, 2012 6:07 pm    Post subject: Reply with quote
hello,
I use attiny 45 for all small uses.
it is possible to use the registers as memory too but it is a big risk (see memory usage in the help)
for an I2C use, I think, you will need too much memory for the 12 or 13
bon courage
JP
