glena
Joined: 25 Jul 2007 Posts: 284 Location: PA near Philly
Posted: Sat Dec 31, 2011 5:23 am Post subject: Test code for reading a L3G4200D triple axes gyro via I2C |
Here is some working test code for initializing and reading the values from a L3G4200D triple axes gyro.
Its tested and working over I2C (hardware or software) on an ATMega1284P
I hope it helps others...
The breakout board used was from: http://dsscircuits.com/l3g4200d-3-axis-gyro.html
I also used the 5v to 3.3v level shifter from: http://dsscircuits.com/i2c-level-converter.html
-Glen
Code: | '===============================================================================
' Project: L3G4200D 3tripple axes gyro Test #1
' Created: 2011-12-23
' Edited: 2011-12-30
' By: Glen Aidukas [bahbots.com]
' Description:
' This is test software for initializing, reading and displaying data from
' the L3G4200D triple axes gyro via I2C on an ATMega1284P
' Note: ANSI (vt100) escape sequences are used to format output.
' Make sure to use ANSI or vt100 terminal type for proper formating.
' Breakout board is from: http://www.dsscircuits.com/l3g4200d-3-axis-gyro.html
' Datasheet: http://www.dsscircuits.com/images/datasheets/L3G4200D.pdf
'=====[ Compiler Directives ]===================================================
$crystal = 18432000
$regfile = "m1284pdef.dat"
$baud = 38400
$hwstack = 64
$swstack = 64
$framesize = 64
'=====[ Global Vars & Constants ]===============================================
dim tick as dword ' used for 100Hz tick count
dim tickn as dword ' used for next timer tick event
dim n as integer ' temp var for visual positioning
dim X as integer
dim Xl as byte at X + 0 overlay
dim Xh as byte at X + 1 overlay
dim Y as integer
dim Yl as byte at Y + 0 overlay
dim Yh as byte at Y + 1 overlay
dim Z as integer
dim Zl as byte at Z + 0 overlay
dim Zh as byte at Z + 1 overlay
dim Temp as byte
dim Status as byte
dim Test_gyro as Byte
'' list of L3G4200D register positions
Const WHO_AM_I = &H0F
Const L3G4200D_R = &HD3
Const L3G4200D_W = &HD2
Const CTRL_REG1 = &H20
Const CTRL_REG2 = &H21
Const CTRL_REG3 = &H22
Const CTRL_REG4 = &H23
Const CTRL_REG5 = &H24
'=====[ Setup Timer0 for Tick isr ]=============================================
Config Timer2= Timer, Prescale = 1024, Compare A = Disconnect, Clear Timer= 1
' crystal / Prescale / CountWanted = reload value
' 18432000 / 1024 / 100Hz = 180 (trigger every 100th sec (10ms))
OCR2A = 180 - 1
On OC2A TickCounter_isr
Enable OC2A
'=====[ I2C BUS INIT ]==========================================================
'configure the scl and sda pins
$LIB "I2C_TWI.LBX" ' uncomment for hardware I2C
'Config Scl = Portc.0 ' uncomment for software I2C
'onfig Sda = Portc.1 ' uncomment for software I2C
Config Twi = 400000
I2cinit
'=====[ Misc Initilization ]====================================================
Config Serialout = Buffered, Size = 254
print "{027}[2J{027}[1;1H"; "Starting..."
print
print "InitGyro: ";
gosub InitGyro
'=====[ Start of main loop ]====================================================
do
if tick >= tickn then
Gosub Read_Gyro
print "{027}[5;1H"; "Count : "; tick ; "{027}[K"
print "{027}[K"
print "Status: "; bin(status ); "{027}[K"
print "Temp : "; temp ; "{027}[K"
print "{027}[K"
print "{027}[10;1H";
print "Gyro-X: "; x ; "{027}[K"
print "Gyro-Y: "; y ; "{027}[K"
print "Gyro-Z: "; Z ; "{027}[K"
'' print visual position of values
print "{027}[10;20H["; : print "{027}[10;60H]";
print "{027}[11;20H["; : print "{027}[11;60H]";
print "{027}[12;20H["; : print "{027}[12;60H]";
n = x /256 : n =n + 40 : print "{027}[10;"; n ; "H|";
n = y /256 : n =n + 40 : print "{027}[11;"; n ; "H|";
n = z /256 : n =n + 40 : print "{027}[12;"; n ; "H|";
print "{027}[13;1H"; "{027}[J";
tickn = tickn + 20
endif
CONFIG POWERMODE = idle
'=====[ Tick timer ISR ]========================================================
TickCounter_isr :
incr tick
return
'=====[ Initilize Gyro]=========================================================
InitGyro :
I2cstart
I2cwbyte L3G4200D_W
I2cwbyte WHO_AM_I
I2cstart
I2cwbyte L3G4200D_R
I2crbyte Test_gyro , Nack
I2cstop
Print "&B"; bin(Test_gyro ); " [&h"; Hex(Test_Gyro ); "]";
' if test_gyro = 11010011 (D3) then connection is ok
I2cstart
I2cwbyte L3G4200D_W
I2cwbyte CTRL_REG1
I2cwbyte &B00000_1111 'Enable x, y, z and turn off power down
I2cstop
I2cstart
I2cwbyte L3G4200D_W
I2cwbyte CTRL_REG2
I2cwbyte &B0010_1001 'adjust/use the HPF
I2cstop
I2cstart
I2cwbyte L3G4200D_W
I2cwbyte CTRL_REG3
I2cwbyte &B0000_1000
I2cstop
I2cstart
I2cwbyte L3G4200D_W
I2cwbyte CTRL_REG4
' I2cwbyte &B0000_0000 'scale 250
' I2cwbyte &B0001_0000 'scale 500
I2cwbyte &B1011_0000 'scale 2000
I2cstop
I2cstart
I2cwbyte L3G4200D_W
I2cwbyte CTRL_REG5
I2cwbyte &B0000_0000 'high-pass filtering of outputs
I2cstop
return
'=====[ Read Gyro Data ]========================================================
Read_Gyro :
I2cstart
I2cwbyte L3G4200D_W
I2cwbyte &B1010_0110 ' (OUT_TEMP AND &B10000000)
I2cstart
I2cwbyte L3G4200D_R
I2crbyte Temp, Ack
I2crbyte Status, Ack
I2crbyte Xl, Ack
I2crbyte Xh, Ack
I2crbyte Yl, Ack
I2crbyte Yh, Ack
I2crbyte Zl, Ack
I2crbyte Zh, Nack
I2cstop
_________________ http://bahbots.com
Posted: Thu Jan 05, 2012 10:51 am Post subject: |
Thanks for sharing. I like the I2C interface due it's little connections and simplicity.
Setting/reading the registers is more work and sample code is just great to get started _________________ Mark |
areefzack
Posted: Fri Jul 12, 2013 12:25 am Post subject: Ask |
What the meaning of this code in the below, the number of 256 and 40 Thanks
Code: | n= x/256 : n=n+ 40 : print "{027}[10;"; n; "H|";
n= y/256 : n=n+ 40 : print "{027}[11;"; n; "H|";
n= z/256 : n=n+ 40 : print "{027}[12;"; n; "H|"; |
glena
Posted: Fri Jul 12, 2013 2:27 am Post subject: |
areefzack,
Its just to scale the values and the using ANSI escape sequences to print at a position on the line to visually show the changes in value.
-Glen _________________ http://bahbots.com |
glena
Posted: Fri Jul 12, 2013 2:29 am Post subject: |
areefzack,
areefzack
Posted: Fri Jul 12, 2013 5:00 am Post subject: |
I have changed the code like this but in hyperterminal not detected anything, you get to help me resolve this?
I just wanted to release the data X, Y, Z which has been filtered
thanks glen
i used the bascom 2.0.7.3
' Description:
$crystal = 12000000
$regfile = "m32def.dat"
$baud = 9600
$hwstack = 64
$swstack = 64
$framesize = 64
Dim Tick As Dword ' used for 100Hz tick count
Dim Tickn As Dword ' used for next timer tick event
Dim N1 As Integer , N2 As Integer , N3 As Integer ' temp var for visual positioning
Dim Xg As Integer
Dim Xgl As Byte At Xg + 0 Overlay
Dim Xgh As Byte At Xg + 1 Overlay
Dim Yg As Integer
Dim Ygl As Byte At Yg + 0 Overlay
Dim Ygh As Byte At Yg + 1 Overlay
Dim Zg As Integer
Dim Zgl As Byte At Zg + 0 Overlay
Dim Zgh As Byte At Zg + 1 Overlay
Dim Temp As Byte
Dim Status As Byte
Dim Test_gyro As Byte
Const Who_am_i = &H0F
Const L3g4200d_r = &HD3
Const L3g4200d_w = &HD2
Const Ctrl_reg1 = &H20
Const Ctrl_reg2 = &H21
Const Ctrl_reg3 = &H22
Const Ctrl_reg4 = &H23
Const Ctrl_reg5 = &H24
Config Timer2 = Timer , Prescale = 1024 ', Compare A= Disconnect, Clear Timer= 1
Ocr2 = 117 - 1
On Oc1b Tickcounter_isr
Enable Oc1b
$lib "I2C_TWI.LBX" ' uncomment for hardware I2C
Config Sda = Portc.1 ' uncomment for software I2C
Config Twi = 400000
I2cinit
Config Serialout = Buffered , Size = 254
'print "{027}[2J{027}[1;1H"; "Starting..."
Print "InitGyro: ";
Waitms 500
Gosub Initgyro
Cls
If Tick >= Tickn Then
Gosub Read_gyro
Print "{027}[5;1H" ; "Count : " ; Tick ; "{027}[K"
Print "{027}[K"
Print "Status: " ; Bin(status ) ; "{027}[K"
Print "Temp : " ; Temp ; "{027}[K"
Print "{027}[K"
Print "{027}[10;1H";
Print "Gyro-X: " ; Xg ; " " '; "{027}[K"
Print "Gyro-Y: " ; Yg ; " " '; "{027}[K"
Print "Gyro-Z: " ; Zg ; " " '; "{027}[K"
Print "{027}[10;20H[" ; : Print "{027}[10;60H]";
Print "{027}[11;20H[" ; : Print "{027}[11;60H]";
Print "{027}[12;20H[" ; : Print "{027}[12;60H]";
Locate 1 , 1
Lcd Xg ; " " ; Yg ; " " ; Zg ; " "
Locate 2 , 1
Lcd Status ; " " ; Test_gyro ; " "
N1 = Xg / 256 : N1 = N1 + 40 ' : Print "{027}[10;" ; N1 ; "H|";
N2 = Yg / 256 : N2 = N2 + 40 ': Print "{027}[11;" ; N2 ; "H|";
N3 = Zg / 256 : N3 = N3 + 40 ': Print "{027}[12;" ; N3 ; "H|";
Print "*" ; N1 ; "," ; N2 ; "," ; N3 ; "^"
Print "{027}[13;1H" ; "{027}[J";
Tickn = Tickn + 20
'Waitms 50
Config Powermode = Idle
Tickcounter_isr :
Incr Tick
Initgyro :
I2cstart
I2cwbyte L3g4200d_w
I2cwbyte Who_am_i
I2cstart
I2cwbyte L3g4200d_r
I2cstop
' Print "&B"; bin(Test_gyro); " [&h"; Hex(Test_Gyro); "]";
I2cstart
I2cwbyte L3g4200d_w
I2cwbyte Ctrl_reg1
I2cstop
I2cstart
I2cwbyte L3g4200d_w
I2cwbyte Ctrl_reg2
I2cstop
I2cstart
I2cwbyte L3g4200d_w
I2cwbyte Ctrl_reg3
I2cstop
I2cstart
I2cwbyte L3g4200d_w
I2cwbyte Ctrl_reg4
' I2cwbyte &B1011_0000 'scale 2000
I2cstop
I2cstart
I2cwbyte L3g4200d_w
I2cwbyte Ctrl_reg5
I2cstop
Read_gyro :
I2cstart
I2cwbyte L3g4200d_w
I2cstart
I2cwbyte L3g4200d_r
I2crbyte Temp , Ack
I2crbyte Status , Ack
I2crbyte Xgl , Ack
I2crbyte Xgh , Ack
I2crbyte Ygl , Ack
I2crbyte Ygh , Ack
I2crbyte Zgl , Ack
I2crbyte Zgh , Nack
I2cstop
glena
Posted: Fri Jul 12, 2013 3:01 pm Post subject: |
areefzack,
I would first un-comment the print "Starting" line and make sure its printing something.
areefzack
Posted: Wed Jul 24, 2013 1:06 am Post subject: |
hi glen, what the unit value for the gyroscope output? dps or rad/s? |
glena
Posted: Wed Jul 24, 2013 6:04 am Post subject: |
areefzack,
I don't remember. It just the raw data from the device so you will need to read the devices documentation.
The code is only meant to test reading the data from the device. Its not doing anything meaningful with the data, just showing the raw values.
snow
Joined: 28 Jun 2005 Posts: 200 Location: Ashburton / Mid Canterbury / New Zealand
Posted: Wed Jul 31, 2019 11:11 pm Post subject: |
Hello. This is a fantastic piece of code !!!
I can get this project working fine... but having some problems understanding this piece of code
Code: |
Read_Gyro:
I2cstart
I2cwbyte L3G4200D_W
I2cwbyte &B1010_0110 ' (OUT_TEMP AND &B10000000) <--------------------------------
I2cstart
I2cwbyte L3G4200D_R
I2crbyte Temp, Ack
I2crbyte Xl, Ack
I2crbyte Xh, Ack
I2crbyte Yl, Ack
I2crbyte Yh, Ack
I2crbyte Zl, Ack
I2crbyte Zh, Nack
I2cstop
The default OUT_TEMP register is 010_0110.. if you run the code with this setting it doesn't work properly.. By putting the extra bit at the start what is this doing to the register??.. I thought this would be reading an entirely different register
Thanks
Snow |
