pwm code problems with ATtiny13 and 15
jasreb
PostPosted: Fri Dec 03, 2004 11:34 pm    Post subject: pwm code problems with ATtiny13 and 15 Reply with quote
Has anyone had any luck using Bascom pwm with ATtiny15 or 13 devices? My code which works fine with 2313 will not compile on either Tiny13 or 15...
With Tiny15 (2 timers, 1 pwm) and following code:
Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Prescale = 8
Pwm1a = 0 ' init pwm
I get error message:
Error : 46 Line : 47 Assignment error [PWM1A: 0 0: 112]
and using Tiny13 (1 timer, 2 pwms) and same code I get same error message, but Tiny13 only has 1 timer/counter, so I tried using
Config Timer0 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Prescale = 8
and I get error message:
Error : 86 Line : 48 Invalid parameter for TIMER configuration [PWM = 8]
Error : 46 Line : 50 Assignment error [PWM1A: 0 0: 112]
Is the problem something I'm doing wrong, or is pwm for ATiny13/15 devices not implemented correctly (yet) in Bascom AVR?
thanks in advance for any advice
Jason
PostPosted: Sat Dec 04, 2004 2:34 pm    Post subject: Reply with quote
hi,
on the T13 and T15 you don't have timer1 (16 bit)
you have it, on the Tiny2313
JP
jasreb
PostPosted: Sat Dec 04, 2004 5:01 pm    Post subject: Reply with quote
I know there's only 8-bit timer, I assume this is called "timer0"?
Whatever, question is still how can you use Bascom pwm command with Tiny13/15? The device hardware supports pwm, 1 on Tiny15 and 2 on Tiny13, just Bascom does not want to compile it..?
(I prefer to use smd 8pin package, which is why I want to use Tiny13 or 15, and I need ADC so 2343 or Tiny22 are not suitable, nor do they have hardware pwm).
Jason
jasreb
PostPosted: Tue Dec 07, 2004 12:01 pm    Post subject: Reply with quote
Hi again
So does anyone know correct syntax to use Bascom pwm with ATtiny13? It won't compile for me. It would save me having to code my pwm by hand, seems a bit silly if the device has one sitting there and I could just be using "pwm1a=xxx" etc ...
I think there might be a prob with the ATtiny13.dat file?
Jason
jasreb
PostPosted: Tue Dec 07, 2004 12:22 pm    Post subject: Reply with quote
Shouldn't there be something in the ATtiny13.dat file like
OCR0A_PORT=PORTB.0 ; Output compare TIMER0A
OCR0B_PORT=PORTB.1 ; Output compare TIMER0B
or something, like there is the the dat files for other devices eg 2313 or Tiny2313? Right now there's nothing in there for OCR pins...
Jason
Frankeman
PostPosted: Tue Dec 14, 2004 11:08 pm    Post subject: Reply with quote
If i do you understand correctly you have found out that Bascom is not supporting the PWM in the Tiny13 at the moment.
This wil not say that you can't use the PWM's in Bascom.
Take a look at the datasheet at http://www.atmel.com/dyn/resources/prod_documents/doc2535.pdf and find the registers that do the job.
Just set the correct register and your PWM will work.
It is not the easyest way but surely very informative.
Frank.
jasreb
PostPosted: Wed Dec 15, 2004 10:35 pm    Post subject: Reply with quote
Hello Frank, thanks for the reply. Do you know where I can find a sample of code to do this (for any device) - I'm not familiar with this syntax, ie do I need to config the timer first, then set the registers, or something else? (How do I set the prescaler for instance)
Thanks in advance for your advice!
Jason
jasreb
PostPosted: Wed Jan 05, 2005 10:18 am    Post subject: Reply with quote
Still wondering - does anybody have any idea why Bascom 'pwm' does not work with ATtiny13? Is it just not implemented (yet) or am I missing something obvious?
Failing that, does anyone have some sample code to program it manually as Frankeman suggests?
thanks in advance...
at90s2343
PostPosted: Fri Jan 14, 2005 12:43 pm    Post subject: Reply with quote
It's likely U have to do some bitbanging.
2 months ago I had the same problem with *fast copy* untill some friendly guy explained me a few things:
QUOTE
the TCCR0 Register doesnt longer exist int the Tiny13
Its divided in TCCR0A and TCCR0B.
The meaning of the Bits in TCCR0A is depend on the BitSettings of BIT3 in
TCCR0B.
The Lower Bits 0 to 2 in TCCR0B sets the prescaler.If these are Zero, the
Timer is stopped.
for the desired Function : PWM,8,Normal, Prescale1 you have to set:
TCCR0A=&b11000011 =&hC3 =195
To set the Prescaler and special PWM modes for timer0 (or stop it) you must
manipulate TCCR0B
and set in our example to:
TCCR0B=&b0000001 =1 for full speed(prescale=1)
TCCR0B=0 to stop the timer0
It should be noted, that Timer0 has two PWM-Channels. Channel B are not
affected in this Calculation.
the Bits 5 and 4 in the TCCR0A will handle this Channel. If you want to use
the Hardwarepin
(Channel A will be set here on Comparematch) You have to select the DDR Register as Output.
UNQUOTE
Try this in a demo version of *fast copy*, compile and have a look at the PINS of the attiny and the timer/counter in AVRSTUDIO. You'll see it works. Then try to re-arrange a few items and try it with BASAVR.
TCCR0A=&b10000001 'Set oc0a on comparematch when DOWNcounting
TCCR0B=&b00000001 ' =1 for full speed(prescale=1)
Set DDRB.0
Ocr0a= 76
The output pin goes 1 when timer is 76 and and goes 0 when 255. After reaching 255 it counts down again and makes output pin 1 when reaching 76...etc.
Good luck
at90s2343
