Ran
Posted: Wed Dec 01, 2004 9:41 am Post subject: I cannot program |
I bought Bascom lately, and..
I have problems with my STK200 Programmer.
Everytime I try to program, the code don't seems to work.
As I remember when programming with my friends programmer,
each time a program was loaded, at the end, the 8 led's did light up.
But with my programmer the 8 led's do not light up at the end of
programming, so I think something is wrong but I cannot find exactly
what.
Can somebody help me?
Thanks,
Ran |
Ran
Posted: Wed Dec 01, 2004 9:53 am Post subject: I cannot progam bis |
I am using DC 12Volts, jp1 open, jp2 closed. |
naicheben
Posted: Wed Dec 01, 2004 1:44 pm Post subject: |
I have the same settings, but 9V.
If you start programming and you don't get any errors, then it might be your code thats wrong. Try to post it. Tell us, witch device you are using. |
Ran
Posted: Wed Dec 01, 2004 2:21 pm Post subject: |
I am using the "8515"
Well here is the program:
'8515in
Dim Adr As Byte , F As Byte , W As Byte , X As Byte
Dim Y As Byte , I As Word
Dim A As Byte , B As Byte , C As Byte , D As Byte
Dim G As Byte
$crystal = 7372800
'inputs=0 outputs=1
Ddra = &B10111101
Ddrb = &B11111111
Ddrc = &B11111011
Ddrd = &B11111011
Open "COMA.0:9600,8,N,1,INVERTED" For Output As #3
' Var op nul zetten
Print #3 , "OK1";
C = 0
D = 0
G = 0
Gosub Schrijf
A = 0
B = 0
C = 0
Lees:
Print #3 , "1";
'lees in A en B
I = 0
Reset Portc.6
Set Portc.6
Set Portc.3
Shiftin Pinc.2 , Portc.4 , I , 0 , 16
Reset Portc.3
B = High(i)
A = Low(i)
Print #3 , B
Goto Lees
Schrijf:
'schrijf C, D en G
Shiftout Portc.5 , Portc.0 , G , 0
Shiftout Portc.5 , Portc.0 , D , 0
Shiftout Portc.5 , Portc.0 , C , 0
Sound Portc.1 , 1 , 1
It simply ouputs with PRINT, but even the Print "OK1"
cannot be found.
Bigger programs from the past who are working fine on my
friends programmer don't work with mine.
Greetings,
Ran |
Posted: Wed Dec 01, 2004 5:48 pm Post subject: |
Start with a simple program first :
$crystal=4000000
config portb=output
toggle portb
waitms 1000
Then compile, program and check.
The jumpers of portb must be inserted. Things to try :
-did you select stk200 programmer?
-do the leds light up while programming
-did you not select 'reverse byte' in Compiler Output ? this option should NOT be checked.
-is external osciallator selected?
-is the thip 90s8515 or mega8515 _________________ Mark |
Posted: Wed Dec 01, 2004 7:29 pm Post subject: |
hi
did you declare a printer ?
did you put the 8515 in the digital 40 ports ?
JP
last did you open the power supply ?
bon courage _________________ pleasure to learn, to teach, to create |
Ran
Posted: Fri Dec 03, 2004 9:09 am Post subject: |
Yes it works !
In Compiler Output I unchecked 'Swap words' and now everything
works fine.
Thank You guys
Thanks and Greetings,
Ran |
