ATIU
Posted: Sat Nov 27, 2004 12:08 pm Post subject: ATMega8 Reset Pin |
I want to use the Mega8 reset pin as an alternate I/O. I am wondering if this will affect ISP (serial) programming capabilities since the reset pin needs to be pulled low before ISP is initiated. Thanks for any help |
sonero
Posted: Sat Nov 27, 2004 1:32 pm Post subject: |
If you disable the reset pin to use it as an I/O, you have no reset pin anymore.
Very obvious.
So serial programming is not possible anymore.
Best regards,
Norbert |
ATIU
Posted: Sat Nov 27, 2004 3:29 pm Post subject: |
How do you get around with this problem? I guess this feature is pretty much useless if you plan to impliment ISP on your board for future upgrades. |
sonero
Posted: Sun Nov 28, 2004 3:36 am Post subject: |
That's it. After you program the fuse to use reset as I/O, you have to use parallel programming to change it back or reprogram the controller.
There's no other way to get around with this.
BTW.: My information is only from the datasheet, just read it.
Best regards,
Norbert |
Posted: Mon Nov 29, 2004 6:20 pm Post subject: |
as sayes Soreno FORGET IT that is a THE problem of the mega8, never touch to the pin C.6
JP _________________ pleasure to learn, to teach, to create |
