Posted: Tue May 09, 2006 12:54 am Post subject: ATTiny13 error message
I'm getting an interesting error message when trying to program an ATTiny13. I'm using registered version 1.11.8.2. Even if I use the sample program in the \chips directory, I get 2 of the following error messages:
Error:70 Line:14 BAUD Rate not possible in file D:\.....\attiny13.bas
I get the message twice, but the program still compiles and I can download and run it just fine. I am not using serial comms and there is no serial configuration settings in the program anywhere. I checked the compiler/chip screen to see if that was causing the problem and, whatever combination of frequency and speed I select, I get a 'not possible' message in the error box.
Anyone got any idea of what's going on or what I might be doing wrong.
that problem is only small bug, but it not affect generated/compiled code. Just ignore that message, if you get .HEX file everything is fine and your program must work without problems in mcu. _________________ Best regards,
/Tomi
