chinas the clone of the classic '51
Goto page Previous  1, 2, 3, 4
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051
Alex-Dan
PostPosted: Sun Feb 23, 2025 5:46 pm    Post subject: Reply with quote
fourth: The compiler settings have a section for setting the end of memory address:
Options >> Compiller >> Misc
Misc> Byte End(Hex)
If this value is set incorrectly, the program does not work.
But the Dat-file has a corresponding section for specifying the size of this memory: IRAM = ###
Is this a feature of the compiler (it is not fully written) or do I not understand something about the operation of this type of uC?
PostPosted: Mon Mar 03, 2025 9:29 pm    Post subject: Reply with quote
the byte end you can set since the program often needs some stack. if you set it to the size of ram you will see you run into problems.
Alex-Dan
PostPosted: Fri Mar 14, 2025 12:24 pm    Post subject: Reply with quote
I see, thank you.
If I understand the compiler's work correctly, then the size of this stack should be calculated approximately the same as for the HWstack in BascomAVR.
plouf
PostPosted: Fri Aug 29, 2025 3:59 pm    Post subject: Reply with quote
albertsm wrote:
support for HW means support for interrupts, serial (uart) and other hardware found in a normal 8051.
the other hardware support depend on how good the info is in the datasheets. i do not have time to do extensive research(puzzling). (unless it is paid for)
so expect the same as for other 8051 processors. and one can always access the registers so it would not be even required.
i have done some projects with Chinese pdf's and these docs are often badly translated. making it a puzzle. but maybe this is the exception and it is not so bad.
i need to finish some other tasks first but i scheduled time to get things done and then i know all about it Very Happy
after 1 year, is any idea in horizon Smile ?
like the decision in chips? some kind of prelimiraly test version can test ?
Christos
Alex-Dan
PostPosted: Sat Aug 30, 2025 12:20 pm    Post subject: Reply with quote
I stopped hoping long ago... Pray
I wrote the subroutines for working with the chips myself.
YES, the previously listed types of variables and other things are very much lacking, but what can you do
I understand perfectly well: respected Mark earns money on AVR and he alone does all the work.
PostPosted: Sat Aug 30, 2025 12:48 pm    Post subject: Reply with quote
As long time users you should know that i do not give release dates. And to be honest i find these kind of messages demotivating.
After the last AVR release i have worked long on the 8051. But since it is an old product it is not a good idea to make some patches. This means i started converting the code so it is more simple to maintain and extend.
A correction: i do not work alone but i have contract workers and family assisting me. But not with all tasks.
Anyway, top priority is always support and that was to be expected after the 2087 release with the TYPE support.
And as all people i need a holiday once in a while.
You also should know i always keep my promise sooner or later.
And as i do not charge for updates it also means that i need to do custom jobs once in a while. Contract workers and the MCS server are not cheap.
plouf
PostPosted: Sat Aug 30, 2025 12:55 pm    Post subject: Reply with quote
I know and understand all these,
I dont feel very "pressuring" to ask after a year Smile sorry if anything like this look like to do:-)
I also not pressure, but ask stuff like "the family of mcu/devices choosen"
So i can have a idea and/or get my own these for my own test in the meanwhile Wink
Christos
PostPosted: Sat Aug 30, 2025 1:05 pm    Post subject: Reply with quote
just do whatever you want. when there is info i share it somewhere on the forum.
Alex-Dan
PostPosted: Tue Sep 16, 2025 7:26 am    Post subject: Reply with quote
Mark, we don't want to offend you Embarassed
You do a great job, and your products are interesting to us! Idea
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051 All times are GMT + 1 Hour
Page 4 of 4
