Initalization of I2C AXTINY3217
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-AVR XTINY/MEGAX/AVRX
kasny.ondrej
PostPosted: Mon Aug 04, 2025 10:24 am    Post subject: Initalization of I2C AXTINY3217 Reply with quote
Hello Mark,
I work with Atxtiny3217 on some project. I use I2c bus for some communication. When code get past I2cinit TWI0, it also enables internal pullups on alternate pins (PA1, PA2) which is undemanded becouse of other connections. I will rewrite it in PORT register back but is it intended behavour?
$regfile = "atxtiny3217.dat"
Config Submode = New
Config Base = 0
$crystal = 20000000
$hwstack = 80
$swstack = 48
$framesize = 150
'$sim
'$dbg
Config Sysclock = 16_20mhz , Prescale = 1
Const _valcheck = 1
Const Updateeprom = 1
Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1 , Baud_offset = Osc20_5v
Config Serialin = Buffered , Size = 60
Config Serialout = Buffered , Size = 100
Config Twi0 = 100000
Config I2cdelay = 100
I2cinit Twi0
Dim Twi_start As Byte
Porta_pin1ctrl = 0 ' need to reassign register bits
Porta_pin2ctrl = 0
'-------------------------------ADC CONFIG---------------------------------
Config Vref = Dummy , Adc0 = 4v3 , Adc1 = 1v1
Config Adc0 = Single , Resolution = 10bit , Adc = Enabled , Reference = Internal , Prescaler = 32 , Sample_cap = Above_1v , Init_delay = 32 , Sample_accu = 4 , Mux = Ain1
Vtg_monitor Alias Porta.1 : Config Porta.1 = Input
Dim Adc_get As Word
Adc_get = Getadc()
Print Adc_get
[/code]
PostPosted: Mon Aug 04, 2025 10:45 am    Post subject: Reply with quote
This is caused by i2cinit which will do a pullup on scl/sda
But for this processor it uses the wrong pins.
You do not need to call i2cinit when you do not need internal pull up. That is : for xtiny platform.
I will change it so the proper default pins will be used
kasny.ondrej
PostPosted: Mon Aug 04, 2025 10:52 am    Post subject: Reply with quote
OK, thank you for explaination.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-AVR XTINY/MEGAX/AVRX All times are GMT + 1 Hour
You can post new topics in this forum
You can reply to topics in this forum
