Serial reading problem AVR128DB28
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-AVR XTINY/MEGAX/AVRX
matjazs
PostPosted: Sun Feb 02, 2025 2:50 pm    Post subject: Serial reading problem AVR128DB28 Reply with quote
I am reading data from an energy meter in this format:
/ISK5\2M551T-200
0-0:96.1.0(84066279)
0-0:97.97.0(00200000)
1-0:0.9.1(210915)
1-0:0.9.2(250129)
1-0:1.8.0(017079.774*kWh)
1-0:1.8.1(008025.728*kWh)
1-0:1.8.2(009054.046*kWh)
1-0:1.7.0(00.853*kW)
1-0:32.7.0(235.3*V)
1-0:52.7.0(233.9*V)
1-0:72.7.0(237.8*V)
1-0:31.7.0(000*A)
1-0:51.7.0(001*A)
1-0:71.7.0(001*A)
1-0:21.7.0(00.118*kW)
1-0:41.7.0(00.270*kW)
1-0:61.7.0(00.294*kW)
1-0:33.7.0(0.690)
1-0:53.7.0(0.889)
1-0:73.7.0(1.000)
It is sent in a packet, it repeats every 10 seconds.
I would like to read only the data in the brackets. The serial buffer is too small (255).
The data is missing from character 255 onwards because the buffer is too small.
Does anyone have any ideas?
Bascom V. 2.0.8.6
oi18ct
PostPosted: Sun Feb 02, 2025 4:23 pm    Post subject: Reply with quote
I think you are trying to receive all data at once into a single variable since its exceeding 255 chars?
So since each line is less than 255 chars, you could receive and parse the data line by line moving data into holding string vars or an array of string.
In your parser, use the carriage return or line feed (13 or 10) to identify the end of a line. That can be a trigger to parse the data of interest and move it into a holding var. The parentheses (ascii dec 40 and 41) are the logic elements to parse out the data of interest.
bascom has good tools that do most of the heavy lifting- if you haven't already, look at ischarwaiting, memcopy and all the logic operations under Strings in the help file. The samples code will have things you can reference as well
Lee
PostPosted: Sun Feb 02, 2025 6:29 pm    Post subject: Reply with quote
Try if this will work since it is not tested. I simply wrote it now.
You have 10 sec period for parse the data so it can be stored in the buffer 512 bytes long for example.
Every received byte prelonge the timeout for parsing the data.
When meter stop sending the data then timeout occur and you can parse.
uC will check for opening bracket and remember where it was. When find the closing bracket then counts the difference betwen start and stop so it can copy the data from Buffer into another buffer but only those bytes betwen the brackets.
This second buffer is an overlay on some Mystring so it can be printed to the second COM port or whatever you want to do with this data.
I hope it will work Very Happy Good luck
$regfile = "AVRX128db32.dat"
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 512
Config Vregpwr = Auto
Config Osc = Enabled , Frequency = 24mhz
Config Sysclock = Int_osc , Prescale = 1
Config Submode = New
Debug On
'*      CONFIG COM1 BUFFERED USART FOR METER           *  'COM1 TXD-PA0-30, RXD-PA1-31 (PA4-26/PA5-27)
Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
 Open "COM1:" For Binary As #1
  Config Serialin0 = Buffered , Size = 100
   Const Meter = 1
'*      CONFIG COM2 BUFFERED USART FOR PC              *  'COM2 TXD-PC0-6 , RXD-PC1-7  (PC4-14/PC5-17)
 Config Com2 = 115200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
  Open "COM2:" For Binary As #2
   Config Serialin1 = Buffered , Size = 100
    Const Usb = 2
'*          TIMER SETTINGS FOR TIME BASE               *
  Config Tca0 = Normal , Prescale = 8 , Run = On
   Tca0_per = 29999                                         '10ms @24MHz/8
'*                PROGRAM VARIABLES                    *
 'programm
 Dim Buffer(512) As Byte , Idx As Word , Msg_timeout As Byte
 Dim N As Word , Start_point As Word , Lenght As Word , Result As Word
 Dim Mystring As String * 10
 Dim Mybuff(11) As Byte At Mystring Overlay
Debug #usb , "{010}Program started"
 If 0 < Ischarwaiting(#meter) Then
   If Idx < 512 Then Incr Idx
   Buffer(idx) = Inkey(#meter)
   Msg_timeout = 50
'-[10ms]-
 If Tca0_intflags.tca_single_ovf_bp = 1 Then
   If Msg_timeout > 0 Then
    Decr Msg_timeout
    If Msg_timeout = 0 Then
     For N = 1 To Idx
      Select Case Buffer(n)
       Case 40 : Start_point = N
       Case 41
        Memfill Mybuff(1) , 11 , 0                          'fill with zeros to terminate string
        Lenght = N - Start_point
        Result = Memcopy(buffer(start_point) , Mybuff(1) , Lenght)
        Debug #usb , Mystring                               'print to second USART
      End Select
     Idx = 0                                                'to be ready for next msg
This is very simple code. I think some safety routines can be added.
Check B-Flash -my MCS bootloader app for Android (updated)
matjazs
PostPosted: Mon Feb 03, 2025 3:26 pm    Post subject: Reply with quote
Thank you very much. I will try this.
PostPosted: Tue Feb 04, 2025 2:27 pm    Post subject: Reply with quote
Sorry. I couldn't resist to test it on the coffe brake.
First I found that second buffer and string is too small because some of the data exeed 10 chars.
Next is to include the closing bracket into the wanted string so "Incr Lenght" is added.
If brackets are unwanted then increase Start_point instead of Lenght (Case 40 : Start_point = N + 1).
Code now works perfectly Wink
I save your data from the Forum in the TXT file (it is 453 byte) and send it over COM1 to the micro with one terminal emulator.
You can watch how data is presented in the second terminal emulator on COM2.
Corrected code below.
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 512
Debug On
   Const Meter = 1
    Const Usb = 2
 'programm
 Dim Mystring As String * 20
 Dim Mybuff(21) As Byte At Mystring Overlay
   Msg_timeout = 50
'-[10ms]-
    Decr Msg_timeout
     For N = 1 To Idx
       Case 41
        Memfill Mybuff(1) , 21 , 0                          'fill with zeros to terminate string
        Incr Lenght                                         '+1
      End Select
matjazs
PostPosted: Wed Feb 05, 2025 9:40 pm    Post subject: Reply with quote
EDC Thank you very much. Your code works OK.
Now I'm trying to add a new array (AD_Buff(20) as string*20) where I want to write the data, but it doesn't work.
Is there a problem with the array declaration or did I something wrong?
This is output:
Program started
$regfile = "AVRX128db28.dat"
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 512
Debug On
Config Com1 = 9600 , Mode = Asynchroneous , Parity = Odd , Stopbits = 1 , Databits = 7
   Const Meter = 1
 Config Com2 = 57600 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
    Const Usb = 2
 'programm
 Dim Am_buff(20) As String * 20                             ' Array for text
 Dim I As Byte
   Msg_timeout = 50
'-[10ms]-
    Decr Msg_timeout
     For N = 1 To Idx
       Case 41
        Incr Lenght                                         '+1
        'Debug #usb , Mystring                               'print to second USART
        Am_buff(n) = Mystring
      End Select
     Gosub Wr_data                                          'Write data to port
Wr_data:
 For I = 1 To 21
  Print #usb , "> " ; Am_buff(i)
PostPosted: Thu Feb 06, 2025 10:45 am    Post subject: Reply with quote
You cannot use variable N for point Am_buff() table. You must declare another
Dim Idx2 As byte
If Idx2 < 20 Then Incr Idx2
Am_buff(Idx2) = Mystring
'and after For-Next loop
Idx = 0 : Idx2 = 0 'so on next parsing, after Incr, we start from Idx2 = 1
And after all "For I = 1 to 20" I think. Not 21
I like to work on some program constants because I can use it in many code cases and they are always keep the track about my declarations.
For example:
Const MyStrArrayLen = 20
Dim Am_buff(MyStrArrayLen) As String *20
If Idx2 < MyStrArrayLen Then Incr Idx2
For I = 1 to Idx2 'because it never exeed 20
 'do something
I can easly change one Constant for increase/decrease size of that array of strings but I dont need to check my whole code.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-AVR XTINY/MEGAX/AVRX All times are GMT + 1 Hour
You can post new topics in this forum
You can reply to topics in this forum
