JamesAus
Posted: Fri Apr 29, 2022 7:17 am Post subject: AVR DB series EEPROM write? |
Hi All,
I have gone down the path of changing over some code from ATMEGA324PB to AVR128DB48, and wow, that isn't such a simple task. One issue I have is that I need to write to the EEPROM at runtime to store user configurable parameters. Before I try to solve that little problem I was wondering if anyone had already done so and would like to share some of their code?
Thanks in advance,
James
(BASCOM-AVR version : 2.0.8.5 ) |
Posted: Fri Apr 29, 2022 8:27 am Post subject: |
when you never used Xmega, it is indeed harder.
it is a good idea to inform us what problems you encountered.
the eeprom is supported so it should work the same as always.
so why you dont show some code that gives problems?
i must add to this that recently i found that between platforms xtiny,megax and DB/DA there are differences in eeprom handling for the UPDI programming. So maybe this applies to internal write as well.
but last time i checked it was good.
so code like this :
Code: | dim eByte as ERAM byte
dim btest as byte
btest=ebyte 'read
print btest
btest=100
ebyte=btest
btest=ebyte 'read
print btest
end
should work. _________________ Mark |
Posted: Fri Apr 29, 2022 11:46 am Post subject: |
it works perfect for me.
Code: |
'name : AVRX128db28-test.bas
'copyright : (c) 1995-2021, MCS Electronics
'purpose : demonstrates AVR128DB28
'micro : AVR128DB28
'suited for demo : no
'commercial addon needed : yes
$regfile = "AVRX128db28.dat"
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 40
'The AVRX series have more oscillator options
Config Osc = Enabled , Frequency = 24mhz
'set the system clock and prescaler
Config Sysclock = Int_osc , Prescale = 1
'configure comparator
Config Ac0 = On , Hysmode = 10 , Mux_pos = Ainp1 , Dacref = &H55
'Some interrupts have multiple trigger options. There is however just one interrupt vector
On Zcd0_falling Isr_zcd
Enable Zcd0_falling 'different settings are possible but there is just 1 interrupt !
Disable Zcd0_both ' you best use the same trigger name but you can use different ones
Enable Zcd0_both
'The REGMODE option is for some statements implicit. Like for PORT_MUX.
Config Port_mux = Overwrite , Evouta = Alt1_pa7 , Ac0 = Alt1_pc6 , Lut0 = Alt1_pa6 , Spi0 = None
Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
'new config VREG POWER option
Config Vregpwr = Auto
'voltage ref
Config Vref = Dummy , Ac = 1v024 , Adc0 = 2v048 , Dac0 = 2v048 , Force_adc0 = Disabled , Force_ac = Enabled
'zero cross detector
Config Zcd0 = Enabled , Runmode = Disabled , Invert = Enabled , Out_enable = Enabled
'brown out detector
Config Bod_vlm = Dummy , Bod_sleep = Disabled , Vlm_threshold = 5above
'opamp
Config Opamp = Enabled , Inp_range = Rail_to_rail , Opamp0_always_on = Enabled , Opamp0_muxbot = Inp , Opamp0_muxneg = Wip , Opamp0_muxwip = R1_6r_r2_10r
'DA converter ,out_enable will set the port direction to output
Config Dac0 = Enabled , Out_enable = Enabled , Runmode = Enabled
'dimension a variable
Dim B As Byte
dim eB as eram byte
eb=10 'write to eeprom
Print "Test USART"
b=eb 'read eeprom
print "ERAM : "; b
Print "Hello" ; Spc(3) ; B
Waitms 1000
Incr B
Isr_zcd:
Zcd0_status = Bits(zcd_crossif_bp) 'reset the interrupt flag
normally the byte is increased in the loop but because of the reading, it is stuck to its value : 10
works in real hardware. _________________ Mark |
JamesAus
Posted: Fri Apr 29, 2022 1:15 pm Post subject: |
Thanks Mark,
I was using Readeeprom & Writeeeprom. I'll change to Dim as Eram variables and hopefully that will solve the problem. Will post an update after I've done so.
Regards
James |
Posted: Fri Apr 29, 2022 1:22 pm Post subject: |
readeeprom/writeeeprom should work as well. but will test that too.
eeprom is a bit tricky in this platform as the memory is mapped different and the mechanism to write is also different.
i do notice that the simulator does not show the eeprom memory correct (due the offset in memory). _________________ Mark |
Posted: Fri Apr 29, 2022 1:32 pm Post subject: |
no problem either :
Code: |
'name : AVRX128db28-eeprom.bas
'copyright : (c) 1995-2022, MCS Electronics
'purpose : demonstrates AVR128DB28 EEPROM
'micro : AVR128DB28
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 40
Dim B As Byte, s as string * 40
dim eb as eram byte
dim eS as eram string * 40
Print "Test ERAM"
input "R/W? ",s
if s="W" then
s="This is eeprom test"
es=s
b=100
eb=b
elseif s="w" then
b=101
WriteEEprom b,0
elseif s="R" then
s=es: print s
b=eb:print b
elseif s="r" then
readeeprom b,0
print b
end if
JamesAus
Posted: Sat Apr 30, 2022 10:45 am Post subject: |
Hi Mark,
I've tried your code, and still no luck. No data is witten to the EEPROM. After writing either way all cells are still &HFF confirmed by downloading eeprom data from micro. There are a couple of changes I've made as below.. (Usart3 used, and AVR128DB48 used) as far as I can see the .dat is correct, certainly the NVM sections that matter in this case.
Code: |
'micro : AVR128DB28
' Changes made...
' AVRX128DB48, not AVRX128DB28
'USART3 used instead
$regfile = "AVRX128db48.dat"
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 40
Config Com4 = 19200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
Open "COM4:" For Binary As #4
dim eb as eram byte
Print #4 , "Test ERAM"
Input #4 , "R/W? " , S
if s="W" then
es=s
b=100
eb=b
Elseif S = "w" Then
b=101
WriteEEprom b,0
Elseif S = "R" Then
S = Es : Print #4 , S
B = Eb : Print #4 , B
Elseif S = "r" Then
readeeprom b,0
Print #4 , B
end if
Close #4
Thanks for your input. .dat file attached.
I've also encountered a couple of other little issues which I've overcome. I'll create additional threads for these when I get all my notes together.
Regards James |
JamesAus
Posted: Sat Apr 30, 2022 10:46 am Post subject: |
Okay...looks like I'm not allowed to attached the .dat  |
Posted: Sat Apr 30, 2022 7:22 pm Post subject: |
when you post non image files, ZIP them.
ZIP is accepted.
but why would you post the DAT if we supply that?
what version is the compiler build? _________________ Mark |
JamesAus
Posted: Sat Apr 30, 2022 8:48 pm Post subject: |
There is (or was) no .dat for the 48 pin
Compiler version :2.0.8.5
Compiler build :2.0.8.5.003
IDE version :2.0.8.5.002
.dat attached
Regards
James |
JamesAus
Posted: Mon May 09, 2022 2:54 am Post subject: |
I was looking at this issue again over the weekend.
It seems that EEERWR is never enabled in NVMCTRL.CTRLA. I'm definitely no expert at assembly, but, is it possible there is a problem in the xtiny.lib as below...
_WriteEEPROM_ClearPage:
Ldi R22,$9D ; ccp spm
Rcall _CheckEpromReady ; check
Ldi R23,4 ; clear page
_WriteEEPROM_Write:
Out CPU_CCP,R22 ;
sts nvmctrl_ctrla,r23 ; command to clear page
Should actually be.....
Ldi R23,$13 ; clear page
_WriteEEPROM_Write:
Out CPU_CCP,R22 ;
Regards,
James |
Posted: Tue May 10, 2022 7:58 pm Post subject: |
the lib has this :
#IF _XTINY<3
..code for xtiny and megax
#else
'code for DB/DA series
ldi r23,&H13 ; command to write
etc.
so it depends on the used platform which code is used.
so maybe you do not have the latest version of the lib?
in that case, contact support. _________________ Mark |
cable
Posted: Sat Feb 25, 2023 6:15 pm Post subject: EEPROM Write |
I also have the problem that I cannot write to the EEprom. Is there already a solution. |
matjazs
Posted: Sun Feb 02, 2025 1:42 pm Post subject: |
I have the same problem.
Where can I get new *.LIB? |
oi18ct
Joined: 08 Mar 2022 Posts: 25 Location: North Branch, Minnesota
Posted: Sat Mar 08, 2025 9:00 pm Post subject: |
Quote: |
PostPosted: Sat Apr 30, 2022 8:48 pm
.dat attached
When I installed BascomAVR, the dat file for AVR128DB48 didn't load or I managed to delete it. I've downloaded the .dat file attached to your post a few years ago.
Is that .dat version current? Where did it come from? Thanks
my installation:
compilier v 2.0.8.6
build 2.0.8.6.001
idc v 2.0.8.6.002 _________________ Lee |
