UPDI
Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Jul 03, 2024 5:12 pm    Post subject: Reply with quote
It's is working well for me : CP2102n VCC=5V with filtering/decoupling capacitors 1µf and 10nF
And
and
JP Wink
ulfbc
PostPosted: Wed Jul 03, 2024 6:11 pm    Post subject: Reply with quote
programmista123 wrote:
Could you try with lower speed? For example 9600.
With CP2102 I can reach 19200 max.
Regards,
Przemek
Edit: I'm using 100 timeout setting, DTR-pin: none.
not that low speed - will try tomorrow
@Duval:
thanks for your input. I've ordered a FTDI Adapter. So I will try this with this Hardware. Should arrive tomorrow
PostPosted: Wed Jul 03, 2024 7:47 pm    Post subject: Reply with quote
JP that is the AVRX series which can work on higher baud.
the xtiny is limited to 900 KHz. so i suggest 115200 baud first.
the protection resistor can be 1K. but only function is to protect the TX.
the voltage is also important. try 5V if possible.
and then of course : is the usb power used to power the circuit?
do all gnd and vcc have a connection?
you best provide more details. cp2102 works best for me.
my timeout is 30.
for the best hardware : get yourself a SNAP programmer from Microchip, it will be supported in the next update.
ulfbc
PostPosted: Thu Jul 04, 2024 8:36 pm    Post subject: Reply with quote
now works fine with a FTDI232 Adapter
thanks to Przemek, JP and Marc
Ulf
ps:
and with CP2102 Adapter as well.
Both wit 1K Resistor between TX and TX
ulfbc
PostPosted: Fri Jul 05, 2024 1:28 pm    Post subject: Reply with quote
The CP2102 is flashing faster. Both driven with 225kBd.
PostPosted: Fri Jul 05, 2024 2:08 pm    Post subject: Reply with quote
@albertsm did you notice that Microchip release SNAP PCBv2 (with new jumper) that have issues with the old Studio and preffer the MPLAB?
Problem described on the polish forum and confirmed by another user.
https://www.elektroda.pl/rtvforum/topic4061309.html
I hope that commandline was not altered.
Check B-Flash -my MCS bootloader app for Android (updated)
PostPosted: Sat Jul 06, 2024 12:21 pm    Post subject: Reply with quote
did not know. but for microchip they are the same. i do not see how i could get such a new pcb v2 to test?
does this snap has a different usb product id?
well my implementation should work anyway. i wonder about the resistor too. you still need to remove a resistor ? (forgot which one it was)
matjazs
PostPosted: Mon Jan 13, 2025 8:53 pm    Post subject: Reply with quote
I bought this UPDI programmer
5893 Voltage UPDI Friend - USB Serial UPDI Programmer ESP32
https://vi.aliexpress.com/item/1005008126747614.html?spm=a2g0o.order_list.order_list_main.4.436c18020T4uHa&gatewayAdapt=glo2vnm
and tried to program my
$regfile = "AVRX128db28.dat"
chip.
It was unsuccessful.
Have any of you tested something like this and what were the results?
programmista123
PostPosted: Tue Jan 14, 2025 8:27 am    Post subject: Reply with quote
Could you share programmer options screenshot?
Do you have any errors?
PostPosted: Tue Jan 14, 2025 11:29 am    Post subject: Reply with quote
interesting.
but is it faster than programming with a CP2102?
jp Wink
PostPosted: Tue Jan 14, 2025 11:41 am    Post subject: Reply with quote
CH340 is not a speed demon Very Happy but it is nomather if it is faster.
When you lock AVR with UPDI you need a 12V pulse to unlock it.
I think even SNAP cant do that.
On the shop site there is a link to oryginal design for this tool so I read documentation. 12V pulse is controlled by RTS signal. It must be low to drive PNP transistor.
Bascom can handle both DTR and RTS signals but only DTR can be inverted as option.
I dont know on which state is RTS signal "normally".
Maybe there is a permanent low state and this tool inject 12V over that PNP transistor so communication cannot be established.
Regardless I order one this little baby for tests Very Happy
matjazs
PostPosted: Tue Jan 14, 2025 8:13 pm    Post subject: Reply with quote
Screenshots are attached. The error is the same with all other option settings (DTR-pin, RTS-Pin >> program/data,HV program, NONE)
JC
PostPosted: Tue Jan 14, 2025 9:53 pm    Post subject: Reply with quote
Above Mark asked about the SNAP V1 and V2 VIDs.
I have both SNAP versions.
The new SNAP V2 has a small 3-Pin header on the SNAP PCB.
It is seen in the photo below, just below the microcontroller chip.
Shorting 1 and 2 is for PICs.
Shorting 2 and 3 is for AVRs.
I've used my SNAP V2 for SPI so far, but I've not yet tested it on an Xmega (PDI), or a UPDI chip.
When I plug the V1 and V2 SNAPs into my Windows PC, I see the following VID info in the Device Manager.
The LEFT info is V2, the RIGHT info is the V1 SNAP.
(The 3D case file / design was on Thingiverse, by ariz0na.)
JC
PostPosted: Thu Jan 23, 2025 12:27 pm    Post subject: Reply with quote
Okay, I got it today. I order it from linked store to be precise.
It is funny for me that it comes with three pin connector JST on the board and four pin plug ahahahaha. So the plug with the wires are useless.
Nomather that I solder a golpin connector (not attached) and connect it to my AVR128DB32 because it is the shortest way to me with this board.
Everything looks like working fine. I can connect and read FuseBits.
I will check the 12V function later.
Please check your connections if you have problem with this adapter. It is working for me.
PostPosted: Thu Jan 23, 2025 1:12 pm    Post subject: Reply with quote
Okay, I test it because Im curious about everything from the birth.
Bascom doing this well. Voltage stays at 5V with this tool.
Only when you config a RTS signal as HV programm then pulse is present at the begining of the sequence.
I set trigger (on oscilloscope) above 5V and rest of communication is 5V-0V shorting to ground.
Now I see that I measure something last time x1 not x10 probe today (This is my fault but not the case here).
Page 4 of 5
