can you help simple the code
kimmi
Moderator
PostPosted: Mon May 15, 2006 11:25 am    Post subject: can you help simple the code Reply with quote
Hey All Bascom users ..
I have made some code for siemens gsm phone for the sms to convert text to pdu format and back
the code looks like someone (like me) that dont know how to make a simple code , can it be more simple strukter so it look better and are more simple to read ....
$regfile = "m128def.dat"
$crystal = 8000000
Dim I As Byte
Dim J As Byte
Dim I1 As Byte
Dim J1 As Byte
Dim Pdu_len As Byte
Dim Smslen As Byte
Dim K As Byte
Dim K1 As Byte
Dim K2 As Byte
Dim K3 As Byte
Dim K4 As Byte
Dim Jj As Byte
Dim Txt As String * 320
Dim Pdutest As String * 320
Dim X As String * 2
Dim X1 As String * 2
Jj = 0
'convert smstxt to pdu
   J = Lookup(jj , Smstxt)
   Incr Jj
Loop Until J = 0
Smslen = Jj - 1
Pdutest = ""
I = 0
J = 1
   K1 = Lookup(i , Smstxt)
   K2 = Lookup(j , Smstxt)
   K = I Mod 8
   Shift K1 , Right , K
   K = 7 - K
   Shift K2 , Left , K
   K1 = K1 + K2
   Print Hex(k1);
   Pdutest = Pdutest + Hex(k1)
   Incr I
   Incr J
   If K = 1 Then
     Incr J
     Incr I
Loop Until I >= Smslen
 'convert(pdu)  to text
Print ""
 Jj = 0
 I = 0
 J = 1
 I1 = 1
 J1 = 3
 Pdu_len = Len(pdutest)
 Pdu_len = Pdu_len / 2
   X = Mid(pdutest , I1 , 2)
   X1 = Mid(pdutest , J1 , 2)
   K1 = Hexval(x)
   K2 = Hexval(x1)
   K = I Mod 7
   K3 = K1
   If K = 0 Then K1 = K1 And 127
   If K = 1 Then K1 = K1 And 63
   If K = 2 Then K1 = K1 And 31
   If K = 3 Then K1 = K1 And 15
   If K = 4 Then K1 = K1 And 7
   If K = 5 Then K1 = K1 And 3
   If K = 6 Then K1 = K1 And 1
   Jj = K + 1
   Shift K1 , Left , K
   K = 7 - K
   Shift K3 , Right , K
   If K = 7 Then
    Print Chr(k1);
   Else
    K1 = K1 + K4
    Print Chr(k1);
    If K = 1 Then
   Print Chr(k3);
   K3 = 0
   K4 = K3
    I1 = I1 + 2
    J1 = J1 + 2
    Incr I
   Incr J
Loop Until I >= Pdu_len
Smstxt:
Data "Hey Bascom Users now I can convert smsmsg from text > pdu and from pdu > text  can you make it more simple in the code ?"
lokking bad right pls help me Embarassed
/ Kim
View user's profile Visit poster's website MSN Messenger
skilcline
PostPosted: Mon May 15, 2006 3:04 pm    Post subject: Reply with quote
If it is a Siemen's mobile phone, the chances are you can send it an AT command to put it in the correct format in the first place - "AT+CMGF=1", if I remember correctly... this would mean that the phone / module will output in SMS Text format and no conversion to and from PDU will be needed.
kimmi
Moderator
PostPosted: Mon May 15, 2006 3:40 pm    Post subject: Reply with quote
Hey ..
Yes some siemens phones can but not all models
ex A65 only pdu
/ Kim
