Installing EMBUD USB-ISP prog on win 10 (64bit)
tolisn
PostPosted: Mon Sep 02, 2024 6:35 pm    Post subject: Installing EMBUD USB-ISP prog on win 10 (64bit) Reply with quote
Hi.
I came back to Bascom after along time of absence due to a required update to one of my projects. Using the latest version (2.0.8.6) I tried to install the driver for the EMBUD USB-ISP programmer but windows says something about corrupt files or something and does not go thru with the instalaltion. As a result Bascom says "USB programmer not found".
I have Win 10 64 bit installed. Are these drivers suitable for this version ?
(BASCOM-AVR version : 2.0.8.6 )
PostPosted: Mon Sep 02, 2024 8:54 pm    Post subject: Reply with quote
If I remember right then EMBUD was such a AVR ISP MKII.
Then, if you don want to download whole Microchip Studio then you need driver-bundle.
After quick search i found it here -> LINK
Download for example "driver ATmel bundle 7.0.888"
After installation search for program Zadig-2.9 because it is the quickest way to add filter and replace driver to libusbK(3.1.0.0)
Run program with admin rights and go to "Options->List all devices". Now search for AVR ISP and replace driver to libusbK.
Then everything should work with Bascom.
Check B-Flash -my MCS bootloader app for Android (updated)
PostPosted: Tue Sep 03, 2024 8:35 am    Post subject: Reply with quote
The ones from EDC will not work since they are not compatible.
you need to use the EMBUD drivers.
in windows you need to disable driver enforcement so you can install the drivers. look on this forum or google for driver enforcement under win10.
tolisn
PostPosted: Tue Sep 03, 2024 6:54 pm    Post subject: Reply with quote
Thank you both for replying. The second solution worked out for me, thanks again.
