Posted: Tue Dec 19, 2023 10:53 am Post subject: DMX Slave - startbyte
HI,
"normel" DMX starts with a start byte value of 0. If RDM will be used... the start byte will have a different value. In that case DMXslave will not store data.
Is there a chance to adjust DMXslave to receive data following a different start byte value?
Is there an internal variable of the received start byte value?
(BASCOM-AVR version : 2.0.8.6 ) _________________ CU
Manfred
Posted: Tue Dec 19, 2023 11:37 am Post subject: Re: DMX Slave - startbyte
The DMX-slave can be found in MCS.lib, it is built as state machine waiting for zero, the exact opcode where that happens is
cpi r24,0
No, but the constant based compare can be exchanged with a variable one
* lds r16, {cust_startbyte}
cp r24,r16
cust_startbyte must be dim'd as byte in main code.
To alter the DMX-function, it is the better way NOT to write to and mess up MCS.lib itself, but to copy the complete DMX-code from MCS.lib into a custom lib.
This custom lib can be altered and included via $LIB directive into code and overrides the original function.
Means by not including custom.lib the original MCS.lib-function is used again and no mess is left.
