Posted: Mon Jun 05, 2023 3:32 pm Post subject: Bug found in BascomAVR 2.0.8.5
Hello
I've found a Bug by using this Programm with selected Controller $Regfile = "m328pdef.dat".
The Toggle-Command in Main-Loop write to wrong Register (PINC.3). Should write to PortC.3
the code is correct. in the datasheet you can find info that writing to the PIN register will actually toggle the PORT register.
Some processors have this option and if so, bascom will use it. _________________ Mark
