Int3 doesn't work on atmega64
Goto page Previous  1, 2
PostPosted: Wed May 24, 2023 7:44 pm    Post subject: Reply with quote
that is called bouncing of contacts. the interrupt simple does its job.
why not monitor the OK message you print? that gives a good clue.
better is to add some counter like :
 Button:
  Print "Ok:"  ; wCounter ; "," ; portb.0
  wcounter=wcounter+1
 Toggle Portb.0
that will give better info. otherwise look up contact bouncing on wikipedia
Printpix52
PostPosted: Thu May 25, 2023 2:29 am    Post subject: Reply with quote
Hello!
This is my actual experimental card I like to work with.
I don't like to experiment with proteus.
I'm done, I put a 104 ceramic condenser in parallel.
I have already read the rebound in encyclopedia.
Thank you so much!![/u][/quote][/url]
PostPosted: Thu May 25, 2023 4:20 pm    Post subject: Reply with quote
Interesting, I've never seen such one.
But tell me, what exactly is the relation of your post to the topic: Int3 doesn't work on atmega64?
You don't use ATMega64.
You don't use the Bascom simulator and
nobody discussed about Proteus.
Do you hear voices in your head? Very Happy
Posting unconnected matter into another one's thread is called thread-hijacking.
This is a good approach to ruin the contacts, as every time pressed, the switch's contact gets a nice discharge.
Contacts may show damage only after lots of use, but generally it's a bad idea.
Printpix52
PostPosted: Fri May 26, 2023 5:46 pm    Post subject: Reply with quote
Each topic that he publishes is a practice for me as an exercise, in addition, there are still many to learn this.
The simulator works well and works very well.
Thank you so much for asking.
PostPosted: Fri May 26, 2023 6:15 pm    Post subject: Reply with quote
In this case to remind you not to hijack other users threads.
Sure I did.
Sure I did, I've used the TO's source and checked his initial problems.
You can do your exercise at home without trashing the TO's thread.
Your self-evaluation is excellent. Very Happy
If you want to learn, open your own threads and don't hijack others.
Then you will see for yourself if other users are interested in your walking attempts.
Printpix52
PostPosted: Fri May 26, 2023 7:43 pm    Post subject: Reply with quote
Ok understood and sorry.
OK
[/quote]If you want to learn, open your own threads and don't hijack others.
ok and understood.
Excuse me teacher and thank you very much MWS. Embarassed Very Happy
PostPosted: Fri May 26, 2023 8:03 pm    Post subject: Reply with quote
Be my guest.
Page 2 of 2
