Posted: Wed May 03, 2006 9:39 pm Post subject: Serial port interrupt
I have a problem with serial port interrupt. In this code the serial interrupt is always working. I've tried with instruction "Clr scon.0" for clear the interrup but it isn't work. A similar code in Bascom AVR works fine, but i have an application with AT89S8252 for this.
$crystal = 12000000
$baud = 4800
'Ledout Alias P3.7
On Serial Intser
Dim Ini_rx As Bit , Serdata As String * 10
Dim Nuevodato As Bit
' Programa Principal
Enable Serial
'Lazo de programa principal
If Nuevodato = 1 Then
Print Serdata
Reset Nuevodato
Intser:
Select Case Sbuf
Case "S":
Ini_rx = 1
Serdata = ""
Case 13:
Ini_rx = 0
Serdata = Serdata + Chr(0)
Set Nuevodato
Case Is > 35:
If Ini_rx = 1 Then
Serdata = Serdata + Chr(sbuf)
End Select
clr scon.0
Joined: 25 May 2004 Posts: 190 Location: Ljubljana, Slovenia
Posted: Fri May 05, 2006 10:59 am Post subject: If
If you communicate with another 8051 like uP who also has 12Mhz crystal, then it si OK,
If you communicate to the device whics sends data at real (not approcsimate) 4800Bdm then your uP does not reads and sends data at 4800 Bd, but approximately 10% faster.
For real 4800 Bd or any other you need cristal with frequency 11059200 Hz!
