sielcon
Posted: Wed Sep 18, 2019 9:30 pm Post subject: ENCODER |
Hello everyone. I was trying to use the Keyes encoder and it really didn't work well with the ENCODER function, I did a small routine in interruptions per level that left me very satisfied.
I leave them in case someone can be useful.
Regards
Code: |
'-------------test encoder rotativo Keyes ------------------------------------------
$regfile = "m328pdef.dat"
$crystal = 16000000
$baud = 19200
$swstack = 128
$framesize = 128
Config Submode = New
Dim Actu As Byte
Portb = &B111
Rota Alias Pinb.0
Rotb Alias Pinb.1
Config Button = Input
Config Rota = Input
Config Rotb = Input
Enable Pcint0
On Pcint0 Isr_pcint0
Pcmsk0 = &B0000011
Actu = 0
Isr_pcint0:
If Rota = 0 Then
Loop Until Rotb = 0
Incr Actu
Print Actu
Goto Isr1
If Rotb = 0 Then
Loop Until Rota = 0
Decr Actu
Print Actu
Isr1:
Rotab = Pinb
Rotab = Rotab And 3
Loop Until Rotab = 3
Waitms 5
Arek2014
sielcon
Posted: Fri Sep 27, 2019 3:50 am Post subject: |
Yes, this is the way to do it, but I use Int0 and Int1 for another application |
CBailey
Posted: Mon Jan 23, 2023 5:53 am Post subject: |
Sorry to dig up an old thread. I'm trying to use an encoder on a Mega328p. I have it working fine using ENCODER, but it just sits there waiting for input. I tried compiling the above code, but got a bunch of errors I couldn't figure out. Should I just configure ENCODER to not wait, and put it in my Do-Loop, or are interrupts the way to go? I'll probably be using interrupts for timers later. |
Posted: Mon Jan 23, 2023 10:17 am Post subject: |
encoder() must be called in a loop, or be triggered by an interrupt, for example a timer. but when you have pcint interrupt you could use that as well.
it depends a bit on the encoder and your app.
when you have problems, you always best show a small as possible piece of code of what you tried. the code posted earlier should work for you too. _________________ Mark |
O-Family
Posted: Mon Jan 23, 2023 11:12 am Post subject: |
Two rotary encoders are available.
Attach a pull-up resistor and a CR noise filter to the encoder input.
If the main routine goes around fast enough, it can be used without interrupts.
Code: |
$regfile = "m88pdef.dat"
$crystal = 8000000
$hwstack = 64
$swstack = 32
$framesize = 24
' * Port name definition *
Encoder_1a Alias Pind.0 'Connection port for [A] pin of rotary encoder [1].
Encoder_1b Alias Pind.1 'Connection port for [B] pin of rotary encoder [1].
Encoder_2a Alias Pind.2 'Connection port for [A] pin of rotary encoder [2].
Encoder_2b Alias Pind.3 'Connection port for [B] pin of rotary encoder [2].
' * Declaring variables *
Dim Encoder1temp As Byte 'Saves the state before the change of the rotary encoder [1]. (b1,b0)
Dim Encoder2temp As Byte 'Saves the state before the change of the rotary encoder [2]. (b1,b0)
Dim Encoder1sta As Byte 'Rotation detection flag for rotary encoder[1]. (Rotate right: [1000_0111], Rotate left: [0100_1011])
Dim Encoder2sta As Byte 'Rotation detection flag for rotary encoder[2]. (Rotate right: [1000_0111], Rotate left: [0100_1011])
Dim Testdata1 As Byte 'Test data for rotary encoder [1].
Dim Testdata2 As Byte 'Test data for rotary encoder [2].
Dim Temp1 As Byte
Dim Temp2 As Byte
' * LCD initial settings *
Config Lcdmode = Port
Config Lcdbus = 4
Config Lcdpin = Pin , Db4 = Portb.3 , Db5 = Portb.2
Config Lcdpin = Pin , Db6 = Portb.1 , Db7 = Portb.0
Config Lcdpin = Pin , E = Portb.4 , Rs = Portb.5
Config Lcd = 16 * 2
Cursor Off
Cls
Testdata1 = 0 'Initialize test data.
Testdata2 = 0
Main:
Gosub Encoderread 'Detects the rotation of a rotary encoder.
' * Processing Rotary Encoder [1] *
Select Case Encoder1sta
Case &B1000_0111 : 'If the rotary encoder [1] is rotating clockwise.
Incr Testdata1
Locate 1 , 1
Lcd Testdata1 ; " "
Encoder1sta = 0
Case &B0100_1011 : 'If the rotary encoder [1] is rotating counterclockwise.
Decr Testdata1
Locate 1 , 1
Lcd Testdata1 ; " "
Encoder1sta = 0
End Select
' * Processing Rotary Encoder [2] *
Select Case Encoder2sta
Case &B1000_0111 : 'If the rotary encoder [2] is rotating clockwise.
Incr Testdata2
Locate 2 , 1
Lcd Testdata2 ; " "
Encoder2sta = 0
Case &B0100_1011 : 'If the rotary encoder [2] is rotating counterclockwise.
Decr Testdata2
Locate 2 , 1
Lcd Testdata2 ; " "
Encoder2sta = 0
End Select
' * Detects the rotation of a rotary encoder *
Encoderread:
Temp1 = Encoder_1a 'Read pin of rotary encoder [1].
Temp1.1 = Encoder_1b
Temp2 = Encoder1temp Xor Temp1 'Compare with the previous state.
If Temp2 <> 0 Then 'Has the rotary encoder [1] changed?
Encoder1temp = Temp1 'Store the state of the change.
Shift Encoder1sta , Left , 2 'Shift the bit state of the pulse by 2 bits to the left
Encoder1sta = Encoder1sta Or Temp1 'Add rotation bit state.
Temp1 = Encoder_2a 'Read pin of rotary encoder [2].
Temp1.1 = Encoder_2b
Temp2 = Encoder2temp Xor Temp1 'Compare with the previous state.
If Temp2 <> 0 Then 'Has the rotary encoder [2] changed?
Encoder2temp = Temp1 'Store the state of the change.
Shift Encoder2sta , Left , 2 'Shift the bit state of the pulse by 2 bits to the left
Encoder2sta = Encoder2sta Or Temp1 'Add rotation bit state.
