Posted: Thu Jan 19, 2023 8:37 pm Post subject: Another point of view for ADC and NTC.
Hello!
As you know, NTC is passive element used mainly for temperature measurement.
Unfortunately this element is non-linear.
On the internet we can see a lot of formulas which can be used and implement. But is there any easier method? I think yes (for me of course ).
1. We will consider NTC connected to the bottom of voltage divider:
2. We need to have information, what is NTC's resistance at temperatures.
In my case: NCP18XV103J03RB (10k @ 25 deg. C, B const.=3900K)
3. We're opening Excel and fill it:
Column M: temperature
Column N: NTC's resistance in Ohm
Column O: R1 - constant (so we're creating 10k to 10k voltage divider at 25 deg. C
Q: Voltage to which voltage divider is connected. In my case: 5.2V
R: Voltage divider output. Vout=(Vin/(R1+Rntc))*Rntc
W: Voltage to counts = Vout/4,096*1024 [4,096 - ADC reference voltage, 1024 - resolution]
Because device will not be working below 0 deg. C, we're creating chart (2D, xy) from 0 deg.C.
As you can see, on the X axis we have ADC counts, on the Y axis - temperature.
4. Adding trend line.
We're clicking on the chart (right click) and pressing: add trend line. We're selecting the closest one. In this case: log. We're clicking also: show equation.
Trend line is a dashed one.
5. Adding code.
We received equation: y=-38,07ln(x)+270,19 and we need to implement it.
Dim ADC_Temp0 asword Dim ADC_Temp0a assingle Dim ADC_Temp0s assingle
