njepsen
Posted: Tue Aug 02, 2022 8:08 am Post subject: driveinit() & initfilesystem() problem resolved |
After some more testing and re-reading the docs several times, the following code runs without creating unexplained errors.
Code: |
$regfile = "m1284pdef.dat"
$crystal = 9830400
$framesize =1500
$hwstack = 400 '
$swstack = 400
'Reset Cause. Must go here
dim breset as byte
breset = getreg(r0)
MCUCSR =0
$frameprotect = 1
config submode = old 'old = need to declare subs or functions
$include "config_mmcsd_hc.inc" 'set up the high capacity SD card comms
'Lots of dims, cofig of subs & functions etc
do
'main loop code
' before any SD card write, sd_error_check is called
loop
function sd_err_check()as byte
're-written 2.08.2022
| Config_mmcsd_HC.inc is included at boot. |
| Driveinit is run when this include happens. |
| This also sets the variables mmcsd_card type and Gbdriveerror |
| If drive error is 0 we can load DOS |
| If a card is removed and reinserted hot,then driveinit and initfilesystem must be re-run |
local error_count as byte
dim miscb as byte
error_count = 0
Select Case Mmcsd_cardtype 'card type is set when we call earlier config mmcsd_hc.inc
Case 1
Print #1, ">. MMC-Card detected"
Case 2
Print #1,">. SD-Card Spec. 1.x detected"
Case 4
Print #1,">> SD-Card Spec. 2.0 detected"
Case 12
Print #1,">> SD-Card Spec. 2.0 High Capacity detected"
Case Else
Print #1,">> No Card detected"
error_count = 3 'this results in 3 retries and exit.
End Select
for n = 1 to 3
if Gbdriveerror = 0 then
$include "Config_AVR-DOS.inc"
print #1, ">> initilise file system"
miscb = initfilesystem(1)
if miscb = 0 then
print #1,"{027}[92m";">> drive init & file init are good"; "{027}[0m" 'green
exit for
else
print #1,"{027}[91m";">> file init is bad"; "{027}[0m" 'red
miscb = driveinit()
end if
else
Print #1,"{027}[91m";">> driveinit is bad"; "{027}[0m" 'red
miscb = driveinit()
end if
error_count = 1
next
sd_err_check = error_count
end function
I'm guessing that the error I was getting was caused by calling driveinit twice but im not sure about this.
Question: what is the difference between including a .bas and a .inc and why the 2 possibilities ? _________________ Neil |
Posted: Tue Aug 02, 2022 11:45 am Post subject: |
what i tried to explain in another reply is that driveinit depends on the driver and hardware.
AVR-DOS supports various media : hard disc, MMC,SD, xram for simulation
each media has a different hardware connection, using SPI, soft spi, ports, or nothing.
driveinit() you find in the lib driver.
for ATA/HD the port pins are brought to the right state and it is checked if there is a drive.
for MMC/SD the SPI is initialized. and the card init procedure is executed. this only has to be done once.
i do not see a reason why it would fail when done a second time. especial when you eject/insert the card.
but is suspect the vcc. there is a difference between you power the whole circuit or just hot swap the card.
there is no difference between including bas or inc files. you can include any file you like. as long it contains bascom code.
long time ago code was not that much so all wend in one bas file. include could be done by including other bas file.
but it is better to use inc so it is clear that this is to be included and will not run on its own. that is why most samples that include files were changed to include INC instead of bas. _________________ Mark |
