socketstat issue
wielklem
PostPosted: Mon May 30, 2022 7:34 pm    Post subject: socketstat issue Reply with quote
I just found the strangest thing in a code i've been using for several projects.
When I connect to a server the socketstat data get's zero but I'm sure the buffer still contains data.
               Tempw = Socketstat(idy , Sel_recv)                        ' get received bytes
               print "socketstat size: ";tempw                  ‘debug the tempw data size
               If Tempw > 0 Then                                         ' if there is something received
                Wresult2 = Tcpread(idy, Incomingtcp)    ‘read the data
                Print incomingtcp                       ‘print the data for debug
        End if
loop until tempw = 0                            ‘end the loop on zero bytes
        printend of loop”                             ‘debug for loop end
now the buffer still contains data and the tempw stays zero. Even when new data is send by the remote connection.
So there is no other way to clear the buffer than to reset the socket (close and reopen it). But that means I loose data that I don't want.
Now what I added as a sort off bug fix is following:
        End if
        incr counter
      if tempw = 0 and counter > 50 then
      print "reconnect......................................................."
      counter = 0
      Socketdisconnect Idy                              ‘close the socket
      Idy = Getsocket(idy , Sock_stream , 1002 , 0)                  'reopen the socket
      Bresult = Socketconnect(idy , ser_digit1.ser_digit2.ser_digit3.ser_digit4 , remoteport , 1)                  'reconnect to the server
      Waitms 1'0
      end if
That actually works, but is not the way I want to leave it. It clears received data without a way to first do something with it.
So I tried something else:
        End if
        Loop until tempw = 0
But that give me the same result.
If I just loop without breaking the loop I get all the data that is send. But than the tcpread will hang on data not being send (waiting for the CR and LF)
Any suggestions?
