Software UART and WAITKEY - Exit if no incoming data
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-AVR old unsupported versions
davidmoran
PostPosted: Thu May 19, 2022 2:10 am    Post subject: Software UART and WAITKEY - Exit if no incoming data Reply with quote
This may have been answered before, but I couldn't' find it in a search.
I guess I am looking for the best way to send and receive binary data over a software serial port.
I added a software UART to an ATMEGA2560 circuit on some unused pins using the OPEN COM...(#4) command. It works fine, and I can get my serial data in and out. However, the only BASCOM command to receive the input data from a software defined UART appears to be the WAITKEY command, and this will wait forever if there is no incoming serial data. I need to be able to exit the WAITKEY command if no data is received after I request it, after some timeout. Do any of the other serial commands like ISCHARWAITING work with the software UART?
I have done some testing, and it appears that if the software UART input is LOW, the WAITKEY will proceed, and return a value of $00, with or without the $TIMEOUT command. However, if the software UART input is HIGH, then the WAITKEY will hang forever. I have tried adding the $TIMEOUT = 1000000 command, but it does not seem to prevent this issue. Perhaps this is because of the Port Number I opened?
Using INKEY or GET instead of WAITKEY seems to give the same results. I cannot use INPUT, because the input is binary data, without CR or LF.
I looked at the newer SERIN and SEROUT commands, but they are only for Strings as well, and I'm not sure if they provide a timeout feature either. Also, the Baud rate calculation seems to be pretty far off, at least in version 2.0.8.2. Perhaps there is a way to use strings with binary data, but since $00 is in the data, I think that would terminate the string.
Any other ideas on how to accomplish this would be appreciated.
Thanks,
Dave
(BASCOM-AVR version : 2.0.8.2 , Latest : 2.0.8.5 )
PostPosted: Thu May 19, 2022 5:13 am    Post subject: Reply with quote
From the Help: "$Timeout - Enable timeout on the hardware UART and software UART."
Works like a charm. Why don`t you upgrade Bascom into 2085?
BTW. All four USARTS from Mega2560 you have used already or this is unefficient design?
davidmoran
PostPosted: Thu Jun 02, 2022 6:14 pm    Post subject: Reply with quote
Thank you for the information. I am switching from a dumb sensor with a TTL logic interface to a smart sensor with a serial interface while using the same IO pins, that is why I need a software-defined UART. The other hardware UARTs are also all in use.
I was using the slightly older version of BASCOM because we have a development environment freeze on this project. I have experimented with the 2.0.8.5 version with similar results.
With the $TIMEOUT command added, I think it is indeed moving past the WAITKEY command with no data input, and with the serial input pin either HIGH or LOW. However, I still see some cases where it appears to hang up, so I am trying to resolve what is happening there. Thanks for the help.
enniom
PostPosted: Fri Jun 03, 2022 2:27 am    Post subject: Reply with quote
DavidMoran,
Difficult to answer your question without a Code Example from you that shows (or occasionally shows) the problem.
E
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-AVR old unsupported versions All times are GMT + 1 Hour
You can post new topics in this forum
You can reply to topics in this forum
