got an error with PWM configuration at ATTiny 85 but works w
ulfbc
PostPosted: Wed May 11, 2022 8:49 pm    Post subject: got an error with PWM configuration at ATTiny 85 but works w Reply with quote
I get an error with PWM configuration at ATTiny 85 but is accepted and works well with ATTiny45.
Bascom Version 2.0.8.4
Error:
Error : 46 Line : 322 Assignment error, unknown variable (DIM) [COMPARE1A: 0 AUSGABE: 6] , in File : D:\OneDrive\AVR\eigene_Progs\sbus-switch-mini-V0.1.0.bas
Error : 46 Line : 326 Assignment error, unknown variable (DIM) [COMPARE1B: 0 AUSGABE: 6] , in File : D:\OneDrive\AVR\eigene_Progs\sbus-switch-mini-V0.1.0.bas
Error : 124 Line : 326 LOOP expected , in File : D:\OneDrive\AVR\eigene_Progs\sbus-switch-mini-V0.1.0.bas
snip of my Code
kanal = kanal1
call magic_code()
Compare1A = ausgabe      'PWM-Ausgang setzen
kanal = kanal2
call magic_code()
Compare1B = ausgabe     'PWM-Ausgang setzen
accected lines starts with "Compare...."
For my understanding my 45'er Code shout work with ATTiny as well.
Only change at the beginning of my code is:
'$regfile="attiny45.dat"
$regfile="attiny85.dat"
(BASCOM-AVR version : 2.0.8.4 , Latest : 2.0.8.5 )
PostPosted: Thu May 12, 2022 8:42 am    Post subject: Reply with quote
There is lack of information about alias for COMPARE1A in the DAT file for Tiny85 but you can use OCR1A instead.
You also can add definition for COMPARE1A in the Tiny85.DAT file.
