ATIU
Posted: Mon Feb 21, 2022 12:11 pm Post subject: Select Case Syntax |
How do you implement a multiple line/statements for a select case statement?
As shown in the example,
[code]
Select Case I
Case 1 : Print "1"
Case 2 : Print "2"
Case 3 To 5 : Print "3-5"
Case Is >= 10 : Print ">= 10"
Case Else : Print "Not in Case statement"
End Select
[/code]
There is only one line to be executed after each "case" is true, how do we implement if there needs to be a multiple lines to be executed for a "case" that is true. Example,
[code]
Select Case I
Case 1 :
Print "1"
X = X + 1
Print X
Case 2 : Print "2"
End Select
[/code]
The above does not work and am not sure how to handle the proper syntax.
Thanks,
Albert
[b][color=red](BASCOM-AVR version : 2.0.8.5 )[/b][/color]
hgrueneis
Joined: 04 Apr 2009 Posts: 902 Location: A-4786 Brunnenthal
Posted: Mon Feb 21, 2022 4:54 pm Post subject: |
Works for me with multiple lines.
I only use one command per line.
Maybe you would try that.
Regards
Huberrt |
ATIU
Posted: Tue Feb 22, 2022 7:14 am Post subject: |
Got it, what I was initially trying to do was;
[code]
Select Case I
Case 1: Print "I=1"
Case 2:
Print "I=2"
X = X + 1
Print " X=" ; X
Case Else
Print "Else"
End Select
[/code]
But as pointed out by EDC, should be this,
Select Case I
Case 1
Print "I=1"
Case 2
Print "I=2";
X = X + 1
Print " X=" ; X
Case Else
Print "Else"
End Select
No ":" after the case statement followed by the multiple lines to be executed if the case is true.
Thanks for the help,
Albert
Posted: Tue Feb 22, 2022 9:44 am Post subject: |
Not even close.
Quote: | But as pointed out by EDC, should be this, |
No. EDC pointed out, that both of his versions actually work.
Read more carefully, including this:
EDC wrote: | Please use "Code" tags when posting. |
If you do not know how code-tags work, feel free to ask. |
ATIU
Posted: Thu Feb 24, 2022 12:38 pm Post subject: |
Sorry MWS, you may have misunderstood.
I already "Got It" and understand where I went wrong using ":" after the case statements. I was trying to understand the help file samples.
Lastly, if you will be kind enough to explain how to use code tags as I am not familiar with such. Thank you,
Albert |
Posted: Thu Feb 24, 2022 8:51 pm Post subject: |
ATIU wrote: | Lastly, if you will be kind enough to explain how to use code tags as I am not familiar with such. |
There are several ways, I'll describe the easiest one.
Select all your code in the message editor:
Dim A As Byte
Dim B As Byte
A = 1
B = A
Then click the 'Code' button.
Code: | Dim A As Byte
Dim B As Byte
A = 1
B = A |
Code is then shown properly and does not mix into the message. |
ATIU
Posted: Fri Feb 25, 2022 1:06 am Post subject: |
Thanks MWS and let me try to edit my previous post for clarity.
Albert |
