BME280 sensor
Goto page Previous  1, 2
O-Family
PostPosted: Wed Jan 12, 2022 9:23 am    Post subject: Reply with quote
I think your program is working fine.
It is possible that the sensor is faulty and should be replaced.
Or maybe you purchased a BMP280.
matjazs
PostPosted: Wed Jan 12, 2022 5:53 pm    Post subject: Reply with quote
Thanks for the help.
Yes, modules can be defects. I bought them on Aliexpress and replaced all three I have - the same result.
I will also order the BMP280.
matjazs
PostPosted: Wed Jan 12, 2022 7:55 pm    Post subject: Reply with quote
Interesting explanation.
https://goughlui.com/2018/08/05/note-bosch-sensortec-bmp280-vs-bme280-sensor-confusion/
O-Family
PostPosted: Thu Jan 13, 2022 12:39 am    Post subject: Reply with quote
If the three modules have the same symptoms, I think the one you bought is the BMP280.
BME280: Temperature, humidity, and atmospheric pressure. (ID:60h)
BMP280: Temperature and atmospheric pressure. (ID:58h)
The prices of BME280 and BMP280 are also very different.
I think you bought it by mistake or the seller shipped it by mistake.
matjazs
PostPosted: Thu Jan 13, 2022 9:12 am    Post subject: Reply with quote
O-Family thank you.
Yes, you are right. My modules are cheap. That means I have BMP280 and not BME280.
This is also the reason that humidity don't work.
I change &H60 with &H58.
Temp(1) = &HD0                                              ' ID register address
I2creceive Slave , Temp(1) , 1 , 1
                                                            'ID BME280-&60H   BMP280-&H58
If Temp(1) = &H58 Then
     Print "Sensor found"                                   ' ID register must return $60
    ' Lcd_text "Sensor found" , 88 , 120 , Darkgreen , White
    Print "Sensor not found"
    ' Lcd_text "Sensor not found" , 64 , 120 , Red , White
   Goto Not_exist
so it can now recognize the module.
I will now order the BME280.
I have another question.
The pressure must be in the range of 10000 pascal. Which unit is mm? I read about 749 to 751.
O-Family
PostPosted: Thu Jan 13, 2022 10:38 am    Post subject: Reply with quote
[mm] stands for millimeter of mercury [mmHg].
1 Pascal = 0.00750062 mmHg
If you omit the calculation below, it is the Pascal value.
Pressure = Press * 0.0075006
[XXXXXX]Pa -> [XXXX.XX]hPa
matjazs
PostPosted: Thu Jan 13, 2022 10:53 am    Post subject: Reply with quote
Thank you very much for your help.
Page 2 of 2
