MichaelB.
Posted: Wed Jan 05, 2022 9:31 pm Post subject: Insertchar is different in 2085 as in 2084 |
I was trying to Figure out the hole Day why my Code isnt Working in 2085 as in 2084.
The Point is that i found a Issue with the INSERTCHAR.
In 2084 , "A" was shown "333333"
In 2085 , "A" is shown "333330"
Michael
$regfile = "m128def.dat"
$crystal = 7372800
$baud = 9600
$hwstack = 30
$swstack = 20
$framesize = 100
$Sim
Dim Pos as Byte
Dim A as String * 6
Dim Input as String * 1
Pos = 1
A = "ÿÿÿÿÿÿ"
B = "3"
DELCHAR Satelit1 , 6 : INSERTCHAR Satelit1, Pos , B
Incr Pos
Incr Pos
Incr Pos
Incr Pos
Incr Pos
DELCHAR Satelit1 , 6 : INSERTCHAR Satelit1, Pos , B |
(BASCOM-AVR version : 2.0.8.5 ) |
Posted: Thu Jan 06, 2022 9:59 am Post subject: |
your sample does not work. i had to modify it. but then it shows a problem : the last character can not be inserted.
as a tip ; you can use mid() statement. this also saves you from delchar first.
anyway this is a bug of course. when the code was changed to allow bigstrings and was also made safe to not allow writing beyond the string, an error was introduced. so the order of the test must be changed.
here is a modified routine. just replace it with the one from mcs.lib and compile the lib
[_INSERTCHAR]
; r20 contains char,r24r25 index,X points to the string
_insertchar0:
Clr R25 ; version without bigstring
_insertchar:
#IF _xmega
* In r23,RAMPZ
Clr r16
* Out RAMPZ,R16
#ENDIF
cpi r24,0 ; check index
brne _InsertChar1 ; not zero
cpi r25,0 ; check both zero
brne _InsertChar1 ; ok
ret ; zero not allowed
_insertchar1a:
cpi r16,0 ; end of string ?
breq _InsertChar2 ; yes so exit
_insertchar1:
ld r16,x+ ; load data
sbiw r24,1 ; dec index
brne _InsertChar1a ; for total index
sbiw r26,1 ; compensate
movw r30,r26 ; copy pointer X to Z
_InsertChar3:
ld r17,z+ ; get byte
st x+,r20 ; write the data
cpi r20,0 ; done when zero
breq _InsertChar2
mov r20,r17 ; now copy the previous saved data
rjmp _InsertChar3 ; and copy all the remaining data
_InsertChar2:
#IF _XMEGA
*OUT RAMPZ,R23
#ENDIF
ret
[END]
and here is your sample i changed to work :
Code: | $regfile = "m128def.dat"
$crystal = 7372800
$baud = 9600
$hwstack = 30
$swstack = 20
$framesize = 100
$Sim
'$lib "mcs.lib"
Dim Pos As Byte
Dim Satelit1 As String * 6
'Dim Input As String * 1
Dim B As Byte
Pos = 1
Satelit1 = "ÿÿÿÿÿ"
B = "3"
'Insertchar Satelit1 , 6 , B
Insertchar Satelit1 , 7 , B
Delchar Satelit1 , 6 : Insertchar Satelit1 , Pos , B
Incr Pos
Incr Pos
Incr Pos
Incr Pos
Incr Pos
Print Satelit1
_________________ Mark |
MichaelB.
Posted: Thu Jan 06, 2022 3:25 pm Post subject: |
Thank you Mark. |
MichaelB.
Posted: Thu Jan 06, 2022 4:07 pm Post subject: |
You know what, the Libmanager wants a Text file. So i saved your Assembler code in a Text File and want to Add it to the MCSlib, after i deleted the "old" _Insertchar Funktion. |
Posted: Thu Jan 06, 2022 4:14 pm Post subject: |
you best replace the code with notepad or with bascom editor (make sure lib is not reformatted).
or simply save the routine in notepad with a new name like : "mynewcode.lib"
then use $lib to include this code instead of the code from mcs
but the best way is to used the editor, select the old text, delete it, and then paste the code from this topic.
i will check what you tried later. _________________ Mark |
Posted: Thu Jan 06, 2022 5:36 pm Post subject: |
First step->
You can always back because you have copy
Second step->
Third->
After save you can compile lib with Lib manager. All steps takes about 1min max |
MichaelB.
Posted: Thu Jan 06, 2022 6:11 pm Post subject: |
Exelent |
Posted: Thu Jan 06, 2022 9:19 pm Post subject: |
Indeed excellent. fully agree.
i added add from clipboard for a next release. that makes it simpler.
and i fixed a bug with [end] _________________ Mark |
