Print" c_ppr= "; Current_ppr ;" ra= "; Raw_angle ;" rc= "; Rotate_count
Do Loop End
If current_ppr is in range [-1,-799] then Rotate_count = -1 but I'd expect that Rotate_count should be 0. If current_ppr>0 then Rotate_count=0. That is ok.
Also example from help (a little changed)
$regfile="m48def.dat"' specify the used micro $crystal=4000000' used crystal frequency $baud=19200' use baud rate $hwstack=32' default use 32 for the hardware stack $swstack=10' default use 10 for the SW stack $framesize=40' default use 40 for the frame space
Dim S AsSingle , Z AsSingle For S =-1To1Step0.1 Print S ;Spc(3);Round(s);Spc(3);Fix(s);Spc(3);Int(s) Next End
it does the same. I've done some workaround but out of curiosity could someone explain me why int() functiuons works in this way>
Regards,
Martin
(BASCOM-AVR version : 2.0.8.2 , Latest : 2.0.8.5 )
