Posted: Wed Dec 01, 2021 12:28 pm Post subject: Over 65535 bytes in external EEPROM.
In my projects, I often use an external FRAM FM25W256 with the fm25c256.lib library (256kbit = 32kbytes). The EEPROM size is indicated on the line $eepromsize = &H8000 (32768 bytes). This memory is not enough for new projects. I want to use FM25V20A (2mbit = 256kbytes), but BASCOM cannot address more than &H10000 (65535 bytes) for EEPROMSIZE command.
How can you get around this? Has anyone used SPI FRAM over 256mbit together with the library?
you best write some custom subs/function. the normal address is 16 bit and extending it to 24 bit means a lot of work. especial with testing.
using a sub to write and function to read is way simpler. _________________ Mark
you are the first that asks. so it will not happen quick.
but you can always contract us to have it made. this is however not a free service. _________________ Mark
