Can we use a higher address in flash for bootload memory ins
sentinel
PostPosted: Wed Dec 01, 2021 2:12 am    Post subject: Can we use a higher address in flash for bootload memory ins Reply with quote
I currently use a mega168 which is 90% full, and would like to add a firmware update capability with bootloader.
Instead of using an external memory chip, can I use the higher unused memory in a Mega328 to store the firmware update, then have the bootloader copy it down to the working area?
(BASCOM-AVR version : 2.0.8.2 , Latest : 2.0.8.4 )
PostPosted: Wed Dec 01, 2021 1:11 pm    Post subject: Reply with quote
If flash is 90% full, an one-to-one copy would use up the same space again, that's 180%.
Not a good idea, don't you think so?
The boot-loader must reside somewhere in flash between &h1C00 and &h1F80, depending on the boot-loader's size.
With 90% full you're at address &h1CCC, which means you can't even use the biggest boot-loader with 1024 words, instead you need one a bit smaller.
So I may miss where you see "higher unused memory".
Do you know at all how a bootloader works?
PostPosted: Wed Dec 01, 2021 1:32 pm    Post subject: Reply with quote
he wanted to use a M328 which has double the space. and i think he means he want to use normal flash space.
but the problem is that you can only write normal flash in boot mode. so the load would need to do 2 things : get the data and store it in 'unused' space.
then move this data to the normal space. for example when a checksum indicates that all is received.
i used unused space to save a good copy so a user could go back in case of a problem.
sentinel
PostPosted: Wed Dec 01, 2021 2:07 pm    Post subject: Reply with quote
Yes, the idea was to have the updated firmware received via Bluetooth and have the serial parser in the main code (not the bootloader) store the new firmware at a higher address.
If the checksum matches, then a flag would be set and the program would jump to the bootloader address, check the flag, then copy the new firmware over the old.
But if only the bootloader can overwrite flash memory, then this wouldn't work.
Since space is limited on the (small) PCB, I thought that the extra cost of the larger MCU would compare well with the cost of an external I2C memory chip.
PostPosted: Wed Dec 01, 2021 3:02 pm    Post subject: Reply with quote
that only works with an external memory. because of the protection you can not write to the normal flash when not in boot mode.
PostPosted: Wed Dec 01, 2021 3:18 pm    Post subject: Reply with quote
You're right, I oversaw it.
sentinel
PostPosted: Wed Dec 01, 2021 11:31 pm    Post subject: Reply with quote
Understood. Thanks Mark.
