help about UPDI and Xtiny, Avr128DB28
PostPosted: Sat Oct 23, 2021 1:17 pm    Post subject: help about UPDI and Xtiny, Avr128DB28 Reply with quote
hi all
I received my avr128DB28 , I looked for 1 simple example in the samples to try my updi interface, I have FTDI, and CP2102) but I didn't find anything that would suit me and that would be suitable for beginners with this µP series
-Turn on a diode ,
or
- send "hello word" on a LCD display
if someone could help me, the doc is 660 pages long, to turn on a diode it's a lot to read Wink
many thanks
I have the XTiny lib
my first tests are disastrous Crying or Very sad
JP
(BASCOM-AVR version : 2.0.8.4 )
SZTRAD
PostPosted: Sat Oct 23, 2021 2:07 pm    Post subject: Reply with quote
Mark's demos aren't working?
RS
PostPosted: Sat Oct 23, 2021 4:23 pm    Post subject: Re: help about UPDI and Xtiny, Avr128DB28 Reply with quote
It must have taken you ages to learn from your students how to pose questions that hold so little content.
Did you forget how this forum works?
Where's your code, where's your schematic, what hardware, what does not work, compiling, flashing or code execution?
PostPosted: Sat Oct 23, 2021 6:42 pm    Post subject: Reply with quote
@MWS I try on this forum to answer questions that users ask, not to return questions.
I would have liked a simple schematic and a simple piece of code
Good thing I don't wait for your sarcastic answers.
On my breadboard I had a bad ground contact
And hooray my little assembly works very well. For the future users I drew the principle. sorry no time to use proteus
[img]
and the code
'name                     : AVRX128db28-test.bas   modified for simple led test JP Duval
'copyright                : (c) 1995-2021, MCS Electronics
'purpose                  : demonstrates AVR128DB28
'micro                    : AVR128DB28
'suited for demo          : Yes now
'commercial addon needed  : yes
$regfile = "AVRX128db28.dat"
$crystal = 24000000
$hwstack = 40
$swstack = 40
$framesize = 40
'The AVRX series have more oscillator options
Config Osc = Enabled , Frequency = 24mhz
Config Sysclock = Int_osc , Prescale = 1
Led Alias Portd.7
Config Led = Output
' test port
Dim , Jbyte As Byte
   For Jbyte = 1 To 4
      Set Led
      Waitms 400
      Reset Led
      Waitms 400
then the result[img]
the green wire is not used
only the yellow one to UPDI
JP Wink
PostPosted: Sat Oct 23, 2021 9:20 pm    Post subject: Reply with quote
Asking the correct questions is my way to help, if it's not up to your taste, then wait for other replies.
Sarcasm served as still friendly hint to have you think about your 'bohoohohooo, it's broken, help me'.
You're a longtime user of this forum to know better.
Is this the answer to my questions?
Then they seem to have helped, and would it be only by making you double check the hardware.
Besides, decoupling capacitors are completely missing, 4.2 page 21 of the data sheet.
