Posted: Wed Oct 20, 2021 5:15 pm Post subject: chip pinout windows |
Hi
I lost the windows pin out [img]
I use 2.0.8.4 or 8.5 and it the same
JP[/img]
(BASCOM-AVR version : 2.0.8.4 ) _________________ pleasure to learn, to teach, to create |
Posted: Wed Oct 20, 2021 6:15 pm Post subject: |
that is odd.
and when you use a different datfile it is still the same?
you can try to reset docking in options, environment, IDE. But as the window is visible i doubt that will work. _________________ Mark |
Posted: Wed Oct 20, 2021 6:18 pm Post subject: |
otherwise post some example code that shows the problem and post the xml option file you use (options, selected setting file will show you which file you have selected. _________________ Mark |
Posted: Thu Oct 21, 2021 4:21 pm Post subject: |
very strange, it's probably because we are approaching Halloween?
I changed the setting for the XML file since 2.0.8.3 was working
the window reappeared.
I changed it again to the xml 2.0.8.4 or 2.0.8.5 and restarted my PC, everything went back to normal
many thanks to talk about xml file
JP _________________ pleasure to learn, to teach, to create |
16mk
Posted: Thu Jul 14, 2022 11:26 am Post subject: |
The same problem, but reset docking as above helps. |
