AVR128DA series
Flash
PostPosted: Sat Oct 09, 2021 8:27 pm    Post subject: AVR128DA series Reply with quote
Is it in plan update, or add on for AVR128DA series? I'm interested for TQFP64 case version MCU. Thanks.
A clever person solves a problem. A wise person avoids it. Albert Einstein
plouf
PostPosted: Sun Oct 10, 2021 10:20 am    Post subject: Reply with quote
whats the advantage of DA vs DB (since DB is planned soon) ?
PostPosted: Sun Oct 10, 2021 11:06 am    Post subject: Reply with quote
DB is planned for 2085. (requires the xtiny add on)
But it does not support DA.
DA is similar without MVIO so it is probably cheaper.
one could tweak a DB version DAT into a DA version. the way i do it : i check the original atmel atdf/inc files and compare them. when there are little differences i manual change it.
when there are a lot of changes i write a converter. for example for xtiny a converter was required. and it is enhanced for each platform. even the converter output need to be checked and edited.
So when will there be DA support? that depends on customer demand. eventually all will be supported but the order depends.
scorpions-cz
PostPosted: Thu Nov 25, 2021 1:56 pm    Post subject: Reply with quote
Hello.
I would like to ask, what does it look like with the 2085 version?
Is the date approximate?
I have one project where I need an AVR128DB64 chip.
Thanks.
Thomas
