Posted: Wed Oct 06, 2021 10:38 pm Post subject: Timer1 set for 8bit PWM -Pin always +5V
Dear All,
I want to control some power MOSFET in a H-Bridge.
The gate of the N-Mosfet is to be controlled by a PWM via a push-pull circuit.
For some reason the PWM outputs are set to +5V. Powerful enough to drive a LED.
This is independent from the value in the OCR1x registers.
Her the code:
Posted: Thu Oct 07, 2021 5:40 pm Post subject: Re: Timer1 set for 8bit PWM -Pin always +5V
autoguider wrote:
As I cannot turn the PWM voltage down I create short circuit.
Mind to explain?
Turning down which voltage gives a short circuit?
There's no such as a PWM-voltage other than the supply voltage for PWM, and PWM means full supply voltage or full GND.
If duty cycle of a PWM is 50%, then half the time its fully supply voltage and half the time it's off, this drives most DMMs nuts.
If this should tell that different PWM-A/B values create a short circuit, then you need to think about what control signals the lower and upper side expects for being active.
In case you supply two PWM-signals which power on lower and upper side at the same time, you truly have a shortcut.
Always 'break before make'.
Beside, the code you show is more than sloppy, I think you can do better.
enableinterrupts' PWM-Timer start
This does not start a timer and why enabling interrupts, if there are none?
What happens after the last line after 'start timer1', happy turnover with reboot?
Dear MWS,
thanks for your comments.
I just got some new processor chips.
Now the code works. The PWM voltage behaves as it should. The MOSFETS are controlled in the proper way.
In my code example I tried to cover any sources of disturbance. That is why I enabled the interrupts.
Now the issue is solved- by replacement of the hardware.
With the new chip the UART makes problems which was not the case with the previous chip
