overlay - MWS
njepsen
PostPosted: Fri Sep 24, 2021 1:21 am    Post subject: overlay - MWS Reply with quote
MWS,
some time ago you commented in another post about the follies of building a string with string = String + newcharacter, for reasons that make really good sense, and you advised overlaying an array over the string.
I am doing what you advised against - is this what you had in mind?
I know you hate people posting code that won't complile but this function is hardware dependent and is 8000 lines long.
Function Getmeterresponse(byval metercommandstr As String) As String
   dim sTemp as string * 250
   dim bArray(250) as byte at sTemp overlay     'overlay the array at the string address
   local Index as byte
   local rxbyte as byte
   Index = 1                                                         'arrays are a based
   sTemp = ""
   Print #3 , ""                                                       'clear meter buffer
   Print #3 , metercommandstr                               'command to meter
      waitms 100                                                 'allow meter time to respond
      While Ischarwaiting(#3) <> 0
         rxbyte = inkey(3)
         bArray(Index) = rxbyte                               'save the byte overtop of the string
         incr index
         bArray(index) = &H0                               'write new string terminator
      Wend
   Loop Until Rxbyte = 10                               '10 = LF from Nor140
   Getmeterresponse = sTemp
End Function
(BASCOM-AVR version : 2082 , Latest : 2.0.8.4 )
Neil
Paulvk
PostPosted: Fri Sep 24, 2021 5:47 am    Post subject: Reply with quote
I did this with the webserver code I created a 250 character string and overlaid the bytes as you have done,
I needed to pull bytes from the wiznet chip , once the bytes were put into the overlay I could then
use string functions to search the bytes (HTTP requests/posts). Note the MEGA1284p was good for this with its 16k of ram.
Also you can use more than one overlay , you could overlay a word , long , double onto the string or all of these at a time
overlay is a very powerful thing.
Regards Paul
PostPosted: Fri Sep 24, 2021 9:18 am    Post subject: Reply with quote
I dont know how your incomming data is transferred and looks like but in your code a &H10 will be added to the string. So maybe..
 Waitms 100
  rxbyte = inkey(3)
   If rxbyte = &H10 Then
     Exit Do
   Else
    incr index
 Wend
You can swallow &H0D (CR) by simple Elseif or Select Case rxbyte.
I also think that some Timeout should be used for this Do loop if LF never arrive.
LoopCnt = 0
 Waitms 100
  rxbyte = inkey(3)
   Select Case rxbyte
    Case &H10
       Exit Do
    Case &H0D
      nop 'swallow
    Case Else
      incr index
    End Select
 Wend
  Incr LoopCnt
Loop Until LoopCnt = 5    'Timeout
PostPosted: Fri Sep 24, 2021 9:51 am    Post subject: Reply with quote
you also need to check that you do not keep writing in case of spurious data arrives.
and instead of inkey() use waitkey() since you already checked that there is data with ischarwaiting()
njepsen
PostPosted: Fri Sep 24, 2021 9:47 pm    Post subject: Reply with quote
Thanks for the comments chaps. This was an edited version of what i have running, and I do have a 2 sec timeout in the do loop in case nothing arrives, but you are correct - the LF does get added to the string and I remove it and spaces after the loop with delchars.
Mark you suggest using waitkey rather than inkey but I don't understand the difference in this context - don't they effectively give the same result after the ischarwaiting?
You make a good point if 'continuous' spurious data arrives and i had not though of that, but the timeout would exit after 2 secs.
I have this running at present.
'meter response looks like      E<space>57.9<cr><lf>
'Note that return to SU0 is 155 bytes long.
'note -  if inner loop gets stuck, AIU watchdogs or times out.
  #if isnoise=1
   Local Timedelay As Long
   local Index as byte
   Index = 1                                               'arrays are 1 based
   Tempstr2 = ""
   Clear Serialin                                           'clear ser buffer
   Print #3 , metercommandstr                    ' CRLF is added automatically
   Timedelay = Local_secl + 2
         rxbyte = inkey(#3)
         incr index
         if rxbyte = 85 or rxbyte = 10 then exit do
      Wend
   Loop Until Local_secl >= Timedelay
   Delchars tempstr2 , 10                                    'LF
   Delchars tempstr2 , 13                                    'CR
   delchars tempstr2 , 32                                    'spaces
   delchars tempstr2 , "E"                                   'valid response
   delchars tempstr2 , "M"                                   'overload
   print #1,">> meter said ";tempstr2
   Getmeterresponse = Tempstr2
  #endif
End Function
Neil
PostPosted: Sat Sep 25, 2021 6:32 am    Post subject: Reply with quote
Why dont select them when they arrives? It is tudious job to search for the delchar function. I dont get it.
Seriously?
PostPosted: Sat Sep 25, 2021 6:43 am    Post subject: Reply with quote
You are a happy men. You have plenty of time for your code Very Happy
I appreciate this Very Happy
PostPosted: Sat Sep 25, 2021 8:28 am    Post subject: Re: overlay - MWS Reply with quote
Yes, this is leaner, as it uses a dedicated pointer to the next char, while the concat '+' always needs to seek the end of string first.
I don't need the book, if everything's available in a chapter. If code is easy to read and it doesn't need to be simulated, I'm fine with that.
Some minor suggestions:
'   sTemp = ""   <-- can be left out, if the following is applied
'         bArray(index) = &H0  <-- saves also some cycles to move it from here
      Wend
         bArray(index) = &H0  ' <-- to there
PostPosted: Sat Sep 25, 2021 8:58 am    Post subject: Reply with quote
         rxbyte = waitkey(#3)
            Select Case rxbyte
               Case 10:
               Case 13:
               Case 32:
               Case "E":
               Case "M":
               Case Else:
                  If Index < 251 Then
                        incr index
            End Select
         Wend
      bArray(index) = &H0
PostPosted: Sat Sep 25, 2021 12:51 pm    Post subject: Reply with quote
iskey first doest a check to see if any data is waiting. while waiting simply wait till data arrives. it uses less cycles/code when you know the data must be there since ischarwaiting is basically the same as inkey with the difference that it does not empty the buffer.
njepsen
PostPosted: Wed Oct 13, 2021 6:45 am    Post subject: overlay Reply with quote
Further to this discussion.
I have been doing some testing.
Because arrays cannot be locals, the declaration must take the form
dim somestring as string * 255            'must be declared before the array
dim bArray (250) as byte at somestring overlay
This means that "somestring" must also be declared as a global?
Now I have just got myself into trouble because I used "somestring" elsewhere in a program as a general purpose string variable , and and it caused a crash after 5 days, which I have not yet got to the bottom of. Being cautious tells me I should use "somestring" only in functions where I use overlay, and to not nest these functions.
comments anyone?
Neil
PostPosted: Wed Oct 13, 2021 11:59 am    Post subject: Reply with quote
yes both need to be global which is the default.
from a technical point of view, it should be possible to use overlay on locals as well. never gave it much thought since using on a normal global var is dangerous enough already.
and no it is not a good idea to use the same name for a variable. only reuse them when both code is not running at the same time.
to save memory it is common practice to have some temp variables you reuse. but then you need to make sure that each time you access that this is allowed.
using the code explorer you can find all instances.
in order to see how to fix it best i would need to see the code.
njepsen
PostPosted: Thu Oct 14, 2021 6:10 am    Post subject: Reply with quote
Hi Mark,
thanks for your input. That pretty much confirms my conclusion that both the array and the overlaid string need to be global.
My fix was really easy My mistake was in using the string var where i should not have used it, so i just declared an array and a 200byte string var that are both used only for the overlay method of receiving serial data.
Neil
