Posted: Mon Aug 30, 2021 7:25 pm Post subject: external programmer
Hi all
i have a strange problem with the external programmer options
I use mkAVRCalculator for programming and after updating to 2.0.8.4 i cannot send the {CHIP} parameter,
if i only use {FILE} parameter everything works but if i use {FILE} {CHIP} as parameter bascom throws an application error on startup..
before the latest version everything was working fine...
I believe this error will be replicated no matter which executable you use...
Theo
(BASCOM-AVR version : 2.0.8.4 ) _________________ Always look for the best and expect the worst
i have 1 pc and 1 laptop and they were working fine before the update ...suddenly they both started to throw application error..i removed
the {CHIP} variable and worked again..
I just tried again with another executable and the error still apears when bascom is started
forgot to add that i tested with 2.0.8.3 and is working fine....
also i have windows 10 21h1 with the latest updats installed.. _________________ Always look for the best and expect the worst
