external programmer
theo64
PostPosted: Mon Aug 30, 2021 7:25 pm    Post subject: external programmer Reply with quote
Hi all
i have a strange problem with the external programmer options
I use mkAVRCalculator for programming and after updating to 2.0.8.4 i cannot send the {CHIP} parameter,
if i only use {FILE} parameter everything works but if i use {FILE} {CHIP} as parameter bascom throws an application error on startup..
before the latest version everything was working fine...
I believe this error will be replicated no matter which executable you use...
Best regards
Theo
(BASCOM-AVR version : 2.0.8.4 )
Always look for the best and expect the worst
plouf
PostPosted: Mon Aug 30, 2021 11:07 pm    Post subject: Reply with quote
i just test with a batch file and they show correct both variables
are you sure text is correct ? (i.e. no greek character) and all capital ?
theo64
PostPosted: Mon Aug 30, 2021 11:24 pm    Post subject: Reply with quote
i have 1 pc and 1 laptop and they were working fine before the update ...suddenly they both started to throw application error..i removed
the {CHIP} variable and worked again..
I just tried again with another executable and the error still apears when bascom is started
forgot to add that i tested with 2.0.8.3 and is working fine....
also i have windows 10 21h1 with the latest updats installed..
PostPosted: Mon Sep 06, 2021 8:50 pm    Post subject: Reply with quote
This is a bug. it will be fixed in 2085.
JC
PostPosted: Mon Sep 06, 2021 10:27 pm    Post subject: Reply with quote
Gosh, that's a long time to wait! : )
JC
