Why the bascom 2.0.8.3 doesn't work with ATMEGA48PB ?
kakadupoznan
PostPosted: Fri Jul 30, 2021 2:21 pm    Post subject: Why the bascom 2.0.8.3 doesn't work with ATMEGA48PB ? Reply with quote
Hello,
I have problem with compile test program for ATMEGA48PB.
If I compile a program for ATMEGA88PB all is OK, but when I compile for ATMEGA48PB then I can't configure PORTE.
If I try config portE, I see error.
It is error 40.
The printscreen is in the attachment.
Maybe does someone know a solution?
Regards
Slawomir
(BASCOM-AVR version : 2083 , Latest : 2.0.8.4 )
PostPosted: Fri Jul 30, 2021 2:47 pm    Post subject: Reply with quote
1 : there is an important rule on this forum ; include some code. And this code should be either posted as is when it is small. Or included as a ZIP file when it is a lot of code.
When you post an image it is ok but only to support what you mean.
anyway i had a look. it appears that the = sign is missing in the dat file.
- open the dat file with notepad (or bascom when you set the option in IDE not the reconfig DAT files)
- search for : DDRE $0D
- insert the = sign : DDRE=$0D
- save
kakadupoznan
PostPosted: Fri Jul 30, 2021 3:56 pm    Post subject: Thanks Reply with quote
It is working.
Thank You. Laughing
