jeremywilson
Joined: 11 Jul 2011 Posts: 79 Location: United States
Posted: Fri Jul 23, 2021 3:42 pm Post subject: ATTINY1604 serial port |
This is my first try at ATTINY1604 serial communication.
I'm testing out the hardware and software serial communications by sending 4 bytes at 38400 baud.
(one gets remarked out while testing the other)
Problem 1:
Printbin sends proper message, except at 600 baud (regardless of baud in Config Com1)
Problem 2:
Serout doesn't do anything (pin starts low, stays low)
Is there something simple I'm overlooking?
Thanks much!
Code: | $regfile = "atxtiny1604.dat" ' ATTINY1604
Config Sysclock = 16_20mhz , Prescale = 2 : $crystal = 10000000 ' 10 Mhz
Config Submode = New
$baud = 38400
Config Com1 = 38400 , Parity = None , Stopbits = 1 , Databits = 8 , Baud_offset = None , Txpin = Alt1_pa1 ' RS485 port
Config Print = Porta.3 , Mode = Set ' RS485 TX enable
' Config Serialin = Buffered , Size = 4 ' RS485 port Rx buffer
' Config Serialout = Buffered , Size = 4 ' RS485 port Tx buffer
' $timeout = 1000000 ' serial port timeout
$hwstack = 40 ' hardware stack size
$swstack = 40 ' software stack size
$framesize = 100 ' frame size
'Port A
Config Porta = &B00111010
Tx0 Alias Porta.1
Rx0 Alias Pina.2
Tx0_enable Alias Porta.3 : Reset Tx0_enable
Dim Rx0_buffer(4) As Byte
Dim Tx0_buffer(4) As Byte
' test message
Tx0_buffer(1) = &HFF
Tx0_buffer(2) = &H00
Tx0_buffer(3) = &HFF
Tx0_buffer(4) = &H00
Main_loop:
Printbin Tx0_buffer(1) , 4 ' transmit message (hardware)
' Set Tx0_enable
' Disable Interrupts
' Serout Tx0_buffer(1) , 4 , Porta , 1 , 38400 , 0 , 8 , 1 ' transmit message (software)
' Enable Interrupts
' Reset Tx0_enable
Wait 1
Goto Main_loop
(BASCOM-AVR version : 2.0.8.4 ) |
Posted: Fri Jul 23, 2021 8:34 pm Post subject: |
1: you best use a simple sample. i always start with the real simple serial.bas
Code: | 'name : serial.bas
'copyright : (c) 1995-2021, MCS Electronics
'purpose : demonstrates USART
'micro : xtiny816
'suited for demo : no
'commercial addon needed : yes
$regfile = "atXtiny816.dat"
$crystal = 20000000
$hwstack = 16
$swstack = 16
$framesize = 24
'set the system clock and prescaler
Config Sysclock = 16_20MHZ , Prescale = 1
'configure the USART
Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Databits = 8 , Stopbits = 1
'dimension a variable
Dim B As Byte
Print "Test USART"
Print "Hello" ; Spc(3) ; B
Waitms 1000
Incr B
End |
- note that $baud is not recommend any longer. you best use config com
- you can try with the default pin used for output but the alternative pin should work equal well
- always establish if the frequency specified with $crystal is actually the running freq. (look up other posts that toggle portb)
- try to leave out other commands and configurations
2: make sure you have an updated version of the add on that matches 2084. in lib manager the lib history will show ; history = 2084.001, serin/serout support added
an update you can get from register.mcselec.com
you can also use 2084 option update for add ons (update addon) _________________ Mark |
jeremywilson
Posted: Sat Jul 24, 2021 12:27 am Post subject: |
Quote: | 1: you best use a simple sample. i always start with the real simple serial.bas |
Config Com1 = 9600 , Parity = None , Stopbits = 1 , Databits = 8 , Baud_offset = None , Txpin = Alt1_pa1 ' RS485 port
Config Serialout0 = Buffered , Size = 4 ' RS485 port Tx buffer
Config Porta.1 = Output ' alt TX
Config Portb.2 = Output ' def TX
Config Portb.3 = Output ' LED
Led Alias Portb.3
Main_loop:
' Print "ABCD"
' Serout Tx0_buffer(1) , 4 , Porta , 1 , 9600 , 0 , 8 , 1 , Inverted
Toggle Led
Waitms 250
Goto Main_loop
End |
Quote: | - note that $baud is not recommend any longer. you best use config com |
removed $baud, kept config com1
Quote: | - you can try with the default pin used for output but the alternative pin should work equal well |
same results on PB2, PA1
Quote: | - always establish if the frequency specified with $crystal is actually the running freq. (look up other posts that toggle portb) |
1. fuse is set for 20Mhz
2. I setup a 38Khz 50% wave based on 20Mhz/Prescale=2 and verified output is 38Khz/50%
Code: | Config Tcb0 = Pwm , Prescale = 2 , Run = On , Ccmp_output = Enabled
Tcb0_ccmp = 17026 ' 66, 131
Quote: | - try to leave out other commands and configurations |
did that as much as possible
Quote: | 2: make sure you have an updated version of the add on that matches 2084. in lib manager the lib history will show ; history = 2084.001, serin/serout support added
you can also use 2084 option update for add ons (update addon) |
XTINY 2.0.8.4
RESULTS:
Printbin and Print output correct data on both pins at 600bps regardless of Config Com1 baud setting.
Serout outputs correct data at correct baud rate on both pins.
Maybe a bad chip???
Thanks, Mark. |
Posted: Sat Jul 24, 2021 7:06 am Post subject: |
as simple as possible means also without the interrupt and buffered mode.
you have a problem with the uart right? so the best thing is to start with the simple mode as i posted before.
then when it is still the same, print the hex values (in the simulator) of the USART registers.
USART0_BAUDH
USART0_BAUDL
USART0_CTRLA
USART0_CTRLB
USART0_CTRLC
and give more info about your hardware. and the programmer you use.
when serout works it means you are using the right clock settings.
odd is that there is a factor 16 between baud and actual baud _________________ Mark |
jeremywilson
Posted: Sat Jul 24, 2021 6:14 pm Post subject: |
Quote: | as simple as possible means also without the interrupt and buffered mode. |
I remarked out Config Serout0 and Enable Interrupts, same result
simulator results:
USART0_BAUDH = &h00
USART0_BAUDL = &h00
USART0_CTRLA = &h00
USART0_CTRLB = &hC0
USART0_CTRLC = &h03
Quote: | and give more info about your hardware. and the programmer you use. |
Atmel ICE programmer (2x3 50mil header)
Microchip Studio
PCB schematic attached
Quote: | odd is that there is a factor 16 between baud and actual baud |
not quite the case: all baud rates (38400, 19200, 9600) all put out 600bps
In light of the sim values above, I added this line before Main_loop:
Code: | Usart0_baud = 1042 ' 38400 bps
' Usart0_baud = 4167 ' 9600 bps
' Usart0_baud = 2083 ' 19200 bps |
Serial port is now working for all baud rates. |
Posted: Sat Jul 24, 2021 8:02 pm Post subject: |
you forgot to specify the mode : Mode = Asynchroneous
if you do not specify mode the baud will not be set. _________________ Mark |
jeremywilson
Posted: Sun Jul 25, 2021 4:23 am Post subject: |
Quote: | you forgot to specify the mode : Mode = Asynchroneous |
I assumed I could leave out options that don't need to change - asynch is the default setting for the Control C register.
Never assume anything !!!
Thanks for the help !! |
Posted: Mon Jul 26, 2021 8:47 am Post subject: |
yes normally that would be true and it is for almost all parameters.
but since the mode is important for the baud calculation, it must be provided. _________________ Mark |
Posted: Mon Jul 26, 2021 8:53 am Post subject: |
and from the help for config com xtiny :
It is preferred to use CONFIG COM instead of using $BAUD.
[PICTURE notice.jpg]It is important that you specify all parameters of CONFIG COM. Do not omit one. The only optional parameter is TXPIN for the alternative TX pin. _________________ Mark |
