Posted: Thu Jun 24, 2021 8:42 pm Post subject: ATMEGA328 with LCD 16x2 + I2C-Controller PCF8574
my BASCOM program works perfectly with an LCD 20x4 + I2C controller PCF8574 and the YwRobot_Lcd_i2c.lib from Kent Andersson.
I changed the program using a 16x2 LCD display with the same controller, but now the text appears shifted 8 places to the right.
Presumably you have to make a correction in the lib to prevent this misalignment.
Question:
has someone solved this problem and what is the name of the lib?
(BASCOM-AVR version : 2.0.8.3 , Latest : 2.0.8.3 )
you best post a small piece of code.
normally only CONFIG LCD should be changed. But i do not really know the mentioned lib.
Did you notice the excellent lib from O-Family in the shared code section? It allows multiple LCD to be used. _________________ Mark
