Proportional Fonts for GLCDs + TrueType Converter
Goto page Previous  1, 2, 3
mariosm
PostPosted: Thu May 27, 2021 11:54 am    Post subject: Reply with quote
Thank you Netzman for your answer.
I have made the changes and now i have one error.
Error : 93 Line : 46 Variable not dimensioned [___READRAMPZ] , in File : ProportionalFont.inc
I do not know what to do about this error.
Do you have a working basic sample without using the proportional fonts library?
I have written my project with libraries from this link
https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&p=73362#73362
All is OK but now i don't want SPI connection.
I have used library for this link
https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13804&postdays=0&postorder=asc&highlight=st7735&start=15
This library use "Config Graphlcd" command but i have problem with font files. I can use only 8x8, 16x16 fonts. Τhis has a bad appearance on display. Any other font files from many converters don't work.
Bascom AVR ver 2.0.8.3 full version
Netzman
PostPosted: Mon May 31, 2021 9:17 pm    Post subject: Reply with quote
Hello,
the RAMPZ register shouldn't be there in the first place since it is a device with 64K of memory. In fact, in the datasheet, the memory address 0x3B (=RAMPZ) is marked as reserved and the errata says, RAMPZ has been removed.
So I guess that just stuck when Mark derived the dat file for this processor.
I've adjusted the font library and compiled it with o-family's glcd-ST7735S_1R8_128x160 driver, see the attachment.
br
LCD Menu | Proportional Fonts
PostPosted: Tue Jun 01, 2021 9:23 am    Post subject: Reply with quote
the RAMPZ is not used when the flash code is 64KB.
At least, not by bascom.
In libs you find code that checks the romsize. Only when it exceeds 64KB it will use rampz.
When this gives problems in user libs, you can simply remark the rampz in the DAT file.
mariosm
PostPosted: Tue Jun 01, 2021 12:11 pm    Post subject: Reply with quote
Thank you again Netzman for your answer.
I used your new files for test.
Τhe result is very good but i have a problem.
The first character of every string is broken.
I also tried different font files with the same problem.
[img][/img]
Netzman
PostPosted: Wed Jun 02, 2021 9:32 pm    Post subject: Reply with quote
I can't reproduce this behaviour, could you upload a complete sample (incl. fonts) which shows that?
Thank you for the explanation, Mark! I resorted to use _huge, which is 0 when the program size is <= 64K and use LPM/ELPM respectively.
thx, br
mariosm
PostPosted: Thu Jun 03, 2021 10:13 am    Post subject: Reply with quote
On attachment you will find the files you need.
I created many different font files with Bascom True Type Font Converter 1.4, but I have the same problem.
Netzman
PostPosted: Sun Jun 06, 2021 12:28 am    Post subject: Reply with quote
In the Pset-Routine resp. the _convert_color1 routine called from there the memory positions in the softstack Y+5 and Y+6 get trashed, which contains the pointers to the frame space for local variables.
I don't think this is intended behaviour, maybe o-family can help there.
This saves/restores the memory positions prior/post calling Pset as a temporary fix (in ProportionalFont.inc, line 193):
                     ' ### OTHER DISPLAYS ###
                     !push R10                              ' save registers used in the font loop,
                     !push R11                              ' they could also be used in the external set pixel routine
                     !push R12
                     !push R13
                     !ld R24, Y+5
                     !push R24
                     !ld R24, Y+6
                     !push R24
                     Pset Xpos , Y , Forecolor              ' or any other set pixel routine
                     !pop R24
                     !st Y+6, R24
                     !pop R24
                     !st Y+5, R24
                     !pop R13
                     !pop R12
                     !pop R11
                     !pop R10
(tested in the simulator)
br
Page 3 of 3
