Modification to the v2.0.8.3 Sample for EDMA RAM Transfer
enniom
PostPosted: Sun May 23, 2021 11:27 am    Post subject: Modification to the v2.0.8.3 Sample for EDMA RAM Transfer Reply with quote
The sample provided needs to be modified by changing the Channel Mode in order for it work properly.
This is the original sample code:
'                  (c) 1995-2020, MCS
'                   xm128A1-DMA.bas
'  This sample demonstrates DMA with an Xmega32E5
$regfile = "xm32e5def.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 40
$framesize = 40
'configure the systemclock
Config Com1 = 38400 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Dim Ar(100) As Byte , Dest(100) As Byte , J As Byte
For J = 1 To 100
    Ar(j) = J                                               ' create an array and assign a value
Print "DMA DEMO"
Config Edma = Enabled , Doublebuf = Disabled , Cpm = Rr     ' enable DMA
'you can configure 4 DMA channels
Config Edmach0 = Enabled , Burstlen = 1 , Chanrpt = Enabled , Tci = Off , Eil = Off , Sar = None , Sam = Inc , Dar = None , Dam = Inc , _
    Trigger = 0 , Btc = 100 , Sadr = Varptr(ar(1)) , Dadr = Varptr(dest(1))
Start Edmach0                                               ' this will do a manual/software DMA transfer, when trigger<>0 you can use a hardware event as a trigger source
For J = 1 To 50
    Print J ; "-" ; Ar(j) ; "-" ; Dest(j)                   ' print the values
The problem is that the Channel Mode is not defined. Transferring values between RAM variables require the channel to defined in Standard Mode.
Possible options for channel mode are :
_ mode = PER0123
_ mode = STD0
_ mode = STD2
_ mode = STD02
The sample code needs to be modified as:
Config Edma = Enabled , Doublebuf = Disabled , Cpm = Rr , Chmode = Std0     ' Modified by specifying the Channel Mode
.... or by choosing one of the other modes with a Standard Channel.
Then the Config EDMACH# needs to be modified to use Channel 0 or 2 - depending on the mode selected.
E
