Atxtiny1616
2New
PostPosted: Sat May 08, 2021 5:59 pm    Post subject: Atxtiny1616 Reply with quote
attached programme shows a lot off errors:
Error : 117 Line : 14 Unknown interrupt [PINC.3]
Error : 86 Line : 20 Invalid parameter for CONFIG parameter or value [IDLE]
Error : 86 Li[ne : 20 Invalid parameter for CONFIG parameter or value [IDLE]
Error : 372 Line : 20 SE entry missing in DAT file
Error : 124 Line : 20 LOOP expected
Who can give me a hand? Thanks in advance.
Best regards
PostPosted: Sat May 08, 2021 8:06 pm    Post subject: Reply with quote
interrupt : 'On Pinc.3 Isr_portc does not exist.
this should be : On Portc_int Isr_portc
writing to PIN register can be done since it is a register, but it is intended for reading. so it will not do much.
On some AVR chips writing to PIN will toggle the PORT. Not so on Xtiny.
So best use the PORT register for this.
config powermode seems to have a bug for xtiny.
but you an simply use a work around :
SLPCTRL_CTRLA=1
!sleep
for IDLE you write a 1
for STANDBY you write 3
and for powerdown you write 5
2New
PostPosted: Sun May 09, 2021 7:21 am    Post subject: ATxtiny1616 Reply with quote
Hi Mark.
Thanks a lot. Good help.
