Power measurement with Atiny85 and small OLED
Insanity
PostPosted: Mon Apr 26, 2021 10:48 am    Post subject: Power measurement with Atiny85 and small OLED Reply with quote
I have a little project here with OLED
For my 12V LED lighting I built a small current, voltage and power measurement.
Evaluation runs via an Atiny85. Supplied from the 12V with 78L05.
Voltage with voltage divider from 12k to 1k
Current with a shunt of 10mOhm
Internal reference = 1.1V
There is no circuit diagram.
Have made adjustments for voltage and current in the program.
' Insanity
' Test mit OLED
$Regfile="M328pdef.dat"
$Crystal=8000000
$hwstack=64
$swstack=64
$framesize=64
' Spannungsteiler mit 12K zu 1K
' Bei 12V = 859 Digits
Const Spannung_Faktor = 12/885
' Shunt mit 0.01 Ohm
' Bei 15A = 140 Digits
Const Strom_Faktor =  15/120
'I2C Config
CONFIG I2CBUS= 0 , SCL=Port , SDA=sda
Config Scl = PortB.2
Config Sda = PortB.0
'Display Config
$lib "glcdSSD1306-I2C.lib"                                  ' SSD1306 LIB einbinden
Config I2cdelay = 1
I2cinit
Waitms 10
Config Graphlcd = Custom , Cols = 128 , Rows = 64 , Lcdname = "SSD1306"       'SSD1106 oder SSD1306
' Anlogfunktionen
Declare Function Analog(byval Kanal As Byte , Byval Anzahl As Word ) As Word
Config Adc = single , Prescaler = Auto , Reference = INTERNAL_1.1
Start Adc
Config Single = Scientific , Digits = 1
Dim Wert_U as Integer
Dim Wert_I as Integer
Dim Ergebnis As Single
Dim Ergebnis_U As Single
Dim Ergebnis_I As Single
Dim Dummy as String * 8
Setfont font12x16
Lcdat 1 , 1 , "Volt"
Lcdat 4 , 1 , "Amp."
Lcdat 7 , 1 , "Watt"
Lcdat 1 , 117 , "V"
Lcdat 4 , 117 , "A"
Lcdat 7 , 117 , "W"
Setfont Digital11x16
  Wert_U = Analog(3,1000)
  Wert_I = Analog(2,1000)
  Ergebnis_U = Wert_U * Spannung_Faktor
  Dummy = Str(Ergebnis_U,1)
  Ergebnis_U = Val(Dummy)
  Dummy = "    " + Dummy
  Dummy = Right(Dummy,4)
  Lcdat 1 , 70 , Dummy
  Ergebnis_I = Wert_I * Strom_Faktor
  Dummy = Str(Ergebnis_I,1)
  Ergebnis_I = Val(Dummy)
  Dummy = "    " + Dummy
  Lcdat 4 , 70 , Dummy
  Ergebnis = Ergebnis_I * Ergebnis_U
  Dummy = Str(Ergebnis,1)
  Dummy = "    " + Dummy
  Dummy = Right(Dummy,5)
  Lcdat 7 , 59 , Dummy
' Analog messen
Function Analog(Kanal , Anzahl)
  Local Schleife As Word
  Local Analogmesswert As Word
  Local Analogmesswert_summe As Long
  Local Analog_mittel As Long
  If Anzahl = 0 Then Anzahl = 1
  Analogmesswert_summe = 0
  For Schleife = 1 To Anzahl
    Analogmesswert = Getadc(Kanal)
    Analogmesswert_summe = Analogmesswert_summe + Analogmesswert
  Analog_mittel = Analogmesswert_summe / Anzahl
  Analogmesswert = Analog_mittel
  Analog = Analogmesswert
End Function
'LCD-Font
$include "font12x16.font"
$include "Digital11x16.font"
