I2C LCD PCF8574 Adapter Library
O-Family
PostPosted: Thu Mar 25, 2021 9:44 am    Post subject: I2C LCD PCF8574 Adapter Library Reply with quote
'lcd_i2c.LIB' and 'bl_lcd_i2c.LIB' have been re-edited for the commercially available PCF8574 I2C LCD adapter board.
You can control multiple LCDs [up to 8] by changing the slave address of PCF8574.
Software I2C and TWI can be changed by [I2c_select].
Circuit diagram
https://drive.google.com/file/d/16oR1toL40Z3vEJHSHsyoLEHTDxihpRLn/view?usp=sharing
Adapter board
https://drive.google.com/file/d/1abm7OaR63MSxJyDIUDMqgCTbxSpUu5zW/view?usp=sharing
https://drive.google.com/file/d/1iT7vKscLrOTqLwyzkuPIuUcTJFoQGDim/view?usp=sharing
https://drive.google.com/file/d/1Wj1bvnkUgL8jYgW72P1cbYl9sbrN6bTz/view?usp=sharing
$programmer = 22                                            'ARDUINO (using stk500v1 protocol)
   '  *  PCF8574 I2C LCD Adapter test  *
   '  *                  2021/ 3/24    *
$regfile = "m328pdef.dat"                                   'Set the AVR to use.
$crystal = 16000000                                         'Set the AVR clock.
$hwstack = 64                                               'Set the capacity of the hardware stack.
$swstack = 10                                               'Set the capacity of the software stack.
$framesize = 24                                             'Set the capacity of the frame area.
   '  * PCF8574 I2C LCD Adapter settings *
   Const I2c_select = 1                                     '0:Software I2C , 1:TWI
#if I2c_select = 0
   '------[For software I2C]------
   Config I2cdelay = 10                                     'SCL clock frequency = approx. 42KHz. (At AVR clock 16MHz) (* Maximum 100KHz)
   Config Scl = Portd.2                                     'Set the port pin to connect the SCL line of the I2C bus.
   Config Sda = Portd.3                                     'Set the port pin to connect the SDA line of the I2C bus.
   I2cinit                                                  'Initialize the SCL and SDA lines of the I2C bus.
#else
   '------[For TWI]------------------
   $lib "i2c_twi.lib"                                       'Incorporate the hardware I2C/TWI library.
   Config Twi = 100000                                      'I2C bus clock = 100KHz
   Config Scl = Portc.5                                     'You must specify the SCL pin name.
   Config Sda = Portc.4                                     'You must specify the SDA pin name.
#endif
   Dim Pcf8574_lcd As Byte : Pcf8574_lcd = &H4E             'PCF8574 slave address. (&H40,&H42,&H44,&H46,&H48,&H4A,&H4C,&H4E)
   Dim Backlight As Byte : Backlight = 1                    'LCD backlight control. (0: off, 1: on)
   $lib "lcd_i2c_PCF8574.LIB"                               'Incorporate the library of I2C LCD PCF8574 Adapter.
   Config Lcd = 20x4                                        'Set the LCD to 20 characters and 4 lines.
   Initlcd                                                  'Initialize the LCD.
   '  * Display test *
   Locate 1 , 1                                             'Display of title.
   Lcd "PCF8574"
   Locate 2 , 2
   Lcd "I2C LCD Adapter"
   Deflcdchar 2 , &H02 , &H04 , &H0C , &H1E , &H0F , &H06 , &H04 , &H08       'Write the custom character [Lightning] to the LCD.
   Locate 1 , 15                                            'Display custom characters.
   Lcd Chr(2) ; "1"
   Locate 1 , 9                                             'Display the slave address of PCF8574.
   Lcd "[" ; Hex(pcf8574_lcd) ; "]"
   Wait 3
   Backlight = 0                                            'Turn off the LCD backlight.
   Locate 1 , 1                                             'Send a dummy command to control the backlight.
   Wait 2
   Backlight = 1                                            'Turn on the LCD backlight.
   Locate 2 , 16                                            'Display the cursor.
   Cursor On , Blink
O-Family
PostPosted: Thu Mar 25, 2021 9:52 am    Post subject: Reply with quote
Multiple LCD codes.
   '  *    For multiple LCDs   2021/ 3/24 *
#if I2c_select = 0
#else
#endif
   '  * When installing the second and subsequent LCDs  *
   Pcf8574_lcd = &H4C                                       'The slave address of the second PCF8574. (&H40,&H42,&H44,&H46,&H48,&H4A,&H4C,&H4E)
   Initlcd                                                  'Initialize the second LCD.
   Pcf8574_lcd = &H4A                                       'The slave address of the third PCF8574. (&H40,&H42,&H44,&H46,&H48,&H4A,&H4C,&H4E)
   Initlcd                                                  'Initialize the third LCD.
   '  * Display test *
   Pcf8574_lcd = &H4E                                       'Specify the first LCD.
   Lcd "PCF8574"
   Locate 2 , 2
   Lcd Chr(2) ; "1"
   '  * Second LCD *
   Pcf8574_lcd = &H4C                                       'Specify the second LCD.
   Lcd "PCF8574"
   Locate 2 , 2
   Deflcdchar 3 , &H02 , &H04 , &H0C , &H1E , &H0F , &H06 , &H04 , &H08       'Write the custom character [Lightning] to the LCD.
   Lcd Chr(3) ; "2"
   '  * Third LCD *
   Pcf8574_lcd = &H4A                                       'Specify the third LCD.
   Lcd "PCF8574"
   Locate 2 , 4
   Deflcdchar 4 , &H02 , &H04 , &H0C , &H1E , &H0F , &H06 , &H04 , &H08       'Write the custom character [Lightning] to the LCD.
   Locate 1 , 19                                            'Display custom characters.
   Lcd Chr(4) ; "3"
   Locate 3 , 3
   Lcd "-- 3rd Line --"
   Locate 4 , 4
   Lcd "20x4 Display "
   Locate 4 , 20                                            'Display the cursor.
   Cursor On , Blink
PostPosted: Thu Mar 25, 2021 10:36 am    Post subject: Reply with quote
Hi O-Family,
A fantastic contribution Very Happy
Thank you for sharing this. You did the lib as it should have been done.
I will add the lib to the distribution too if you don't mind.
O-Family
PostPosted: Fri Mar 26, 2021 12:45 am    Post subject: Reply with quote
Hope it helps many users!
aphawk
PostPosted: Fri Mar 26, 2021 9:25 pm    Post subject: Reply with quote
Only to inform that this new library has ceased all Proteus simulation problem that I have for some years .... now the display works for more than 10 minutes without any problem.
Tried in 3 different projects, all works perfect now !
The old library makes simulation erratic after one or two minutes...
Thanks for all people involved in this actualization !
Paulo
O-Family
PostPosted: Tue May 04, 2021 2:19 am    Post subject: Reply with quote
Fixed a bug when using USI.
Please reload the library.
I don't have the XTINY add-on, so I'm not sure if it works with XTINY.
$programmer = 16                                            'USBprog Programmer/ AVR ISP mkII (Atmel)
'$prog &HFF , &H62 , &HDF , &HFF                             'Fuse setting. (ATtiny85 factory shipping condition)
   '  *     (For USI)    2021/ 5/ 3    *
$regfile = "ATtiny85.DAT"                                   'Set the AVR to use.
$crystal = 1000000                                          'Set the AVR clock.
$hwstack = 40                                               'Set the capacity of the hardware stack.
   Const I2c_select = 1                                     '0:Software I2C , 1:USI
#if I2c_select = 0
'   $lib "i2cV2.LBX"                                         'Incorporate a modified version of the I2C library.
   Config I2cdelay = 10                                     'SCL clock frequency.  (*Up to 100KHz)
   Config Scl = Portb.2                                     'Set the port pin to connect the SCL line of the I2C bus.
   Config Sda = Portb.0                                     'Set the port pin to connect the SDA line of the I2C bus.
#else
   '------[For USI]------------------
   Config Usi = Twimaster , Mode = Normal                   'USI master settings. (I2C bus clock = 100KHz)
#endif
   '  * Display test *
   Lcd "PCF8574"
   Locate 2 , 2
   Lcd Chr(2) ; "1"
   Wait 3
   Wait 2
   Cursor On , Blink
PostPosted: Tue May 04, 2021 9:21 am    Post subject: Reply with quote
thank you for the update. Very Happy
