Nextion and Bascom
Goto page Previous  1, 2, 3, 4
Kasch
PostPosted: Mon Oct 26, 2020 5:25 pm    Post subject: Reply with quote
how can I send it to you?
PostPosted: Mon Oct 26, 2020 6:41 pm    Post subject: Reply with quote
do a zip file to jp030405 at yahoo.fr
Kasch
PostPosted: Mon Nov 09, 2020 11:40 am    Post subject: Reply with quote
sorry for late answere, i have sent it
PostPosted: Mon Dec 14, 2020 6:30 am    Post subject: Get ASCII Reply with quote
I have been working to make sending to the nextion faster.
So to do this you need to just send the data to the display
and then process on the display to put in the boxes
but we need error checking nextion does modbus crc16
but I wanted xmodem crc16 and nextion has no command
to give the ascii value of a character so I have written
it myself and here is a demo page
it loads characters 32 to 126 int nextion eeprom
then you can search the eeprom and get the ascii value of a character you enter.
Next I will post the xmodem crc16
and then put it all together to send packets of data to the nextion from the avr with
both types of crc16
Regards Paul
PostPosted: Mon Mar 22, 2021 7:05 am    Post subject: CRC16 generator Reply with quote
Here is code that generates CRC16 for a string you first have to run the
previous program once to put the characters ! to ~ in the eeprom
(Note if you use other characters you will need to add them)
to enable it to look up and calculate the character ASCII number
This enables CRC checking of bytes sent to the nextion from the AVR
and those sent to the AVR
Regards paul
//calculate crc16 of string
//put in button code to demo
//Variables needed
//text variables >TXT1,TXT2
//Number variables >char,crc,count,i,j,k,l
//t0 holds the string n0 shows result
strlen t0.txt,count.val //get length of string
NUM1.val=0 //start a first character
crc.val=0
k.val=count.val
n1.val=count.val
count.val=0
while(k.val>0)
  //substr <src>,<dest>,<start>,<count>
  char.val=0
  substr t0.txt,TXT1.txt,count.val,1
   NUM1.val=1
  l.val=0
   while(NUM1.val<96)
      repo TXT2.txt,l.val //get character from eeprom
      l.val+=4
      NUM1.val+=1
      if(TXT1.txt==TXT2.txt)//match in eeprom
        char.val=NUM1.val
        char.val+=30
        NUM1.val=99
            char.val=char.val<<8
            crc.val=crc.val^char.val
            i.val=8
           while(i.val>0)
             j.val=crc.val&0x8000
             if(j.val==0x8000)
              crc.val=crc.val<<1
              crc.val=crc.val^0x1021//this can be changed for other
                                    //crc polynomials
              //print "one"
                }else
                crc.val=crc.val<<1 //left crc shift 1
               crc.val=crc.val&0xFFFF
               i.val-=1
          count.val+=1
         NUM1.val+=1 //increment by 1
         k.val-=1 // decrement by 1
   //n2.val=count.val
   n0.val=crc.val
  // printh crc.val
Page 4 of 4
